Results 1 to 13 of 13
Thread: Average Idle Speed
08-29-2009, 10:32 AM #1
Average Idle Speed
Whats your guys average idle speed, working on adjusting my TB. I have a stock cam......and go!
08-29-2009, 03:54 PM #2
no one??? I guess you guys dont have working engines....mine was around 500rpm's and I raised it to about 750rpm's seems to be running better. Tomorrow I will hook it up to obdII to get the exact rpm's
08-29-2009, 04:08 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
Guessing A4? Open loop or closed loop? In gear foot on the brake or Park/Neutral? Before tuning mine was 646-676 P/N, 525-585 in gear on a scanner.
08-29-2009, 04:17 PM #4
A4, closed, park
08-29-2009, 05:58 PM #5
I want to say it is right around 580-ish in park. I just remember thinking it has kind of a low idle rpm after we bought it. Will try to check it with my scanner tomorrow.
__________________________________________________
Just checked it with my scanner about an hour ago. Engine warm, in park, A/C off, cooling fan running and it was 630-650.Last edited by pajeff02; 08-30-2009 at 01:19 PM. Reason: More information
08-31-2009, 06:52 AM #6
I bumped mine up in the tune on both cars. Didn't like how low they idled. One's an auto and the other a manual.
I have the auto idle about 650 in gear with AC on and off,,, and 750 in park.
I have the manual idle at 800 because it has a smallish cam, and I wanted to smooth it out a bit. But it idles down to 600 if you want it to.
08-31-2009, 07:08 AM #7Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
As per the stock tach, a4, in d, foot on brake = between 500 to 550
08-31-2009, 11:20 AM #8
A few things about this thread....
1. Your stock tach is not accurate, so if you are going by that, you are ill-advised, you must use a scan tool.
2. You can't raise the idle with a set screw, the PCM fights for what it is programmed to idle at. If you jack it open far enough, your TPS will not read 0% which will cause an issue.
3. If you actually GET a raised idle, you will get a code and you are causing issues that are not apparent to you now. A side is that your IAC is now fully closed as it fights against the extra air you are letting in. On a hot day, your idle will idle wander higher and want to hang, especially with the car moving.
4. Your extra un-accounted for airflow will make the car 'push' when it is moving.
08-31-2009, 11:22 AM #9
08-31-2009, 11:28 AM #10
It's very low, at full temp it's 650 in P/N and 550 in gear.
08-31-2009, 02:41 PM #11
frost after I installed my ported TB, my car seemed to be idling too low, it just didnt sounds right.....So I adjusted the screw on the TB, now it idles around 750 and in gear around 550 to 600. It seems to run better now. Do you think this is ok. I still havent hooked it up to my scanner. Being lazy may do it later
09-02-2009, 05:17 PM #12
09-02-2009, 07:39 PM #13
What's Your Idle Speed?
By Naaman in forum General HelpReplies: 111Last Post: 01-13-2013, 02:24 PM -
idle speed
By m1a2d3 in forum Camaro / SSReplies: 8Last Post: 09-15-2008, 12:46 PM -
high idle speed ???
By paq in forum General HelpReplies: 4Last Post: 04-07-2007, 06:50 AM -
Stock idle speed
By IRACE2 in forum General HelpReplies: 21Last Post: 03-01-2006, 03:42 PM
