Results 1 to 20 of 31
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Bent Push Rods on LS1 M6 Cars?
    What are you guys replacing the bent push rods with? Need ideas on Brands and types of material. Are the hollow stem LS6 good replacements on a stock
    motor with a possible mild cam upgrade at a later date. Thanks.
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    look for some chromemoly push rods, call up crane or comp cams, they will be able to hook you up
    Lost in Texas
    Custom Slate Blue
    99 B4C
    yeh, got some better pushrods. . .and stop missing shifts, lol. They are all hoolow, oil flows through them
    Valvetrain stock??
    If so, keep it that way. Replace with GM stock pushrods. Help prevent damage in case of over-rev from a missed shift.
    Lowered, HID's, tinted.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Valvetrain stock??
    Good point
    dont worry about it
    01 Z28
    i have the hardened ones from texas speed seems to be good 7.400
    nj
    90 Mustang 5.0
    the benefit of aftermarket pushrods vs stock pushrods on the ls1 and pretty much all factory installed pushrods are the pressed balls on the ends of the pushrods on stock ones, and the tensile strength/diameter being weaker. Basically stock ones can break and or bend do to deflection.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    right, but luos' point is that if all of your valvetrain is stock and you upgrade pushrods, the next time you miss a shift somthing else will break when the pushrod doesn't give. It's better to bend a pushrod than bend a valve, break a spring, or collapse a lifter
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    I just pulled my valvetrain apart and found that I had bent pushrods. Missed the 3rd to 4th shift a couple times and went to 2nd, that will do it. I got Comp Cams pushrods from Speed Inc to replace the old ones. The stock LS1 pushrods are just too weak, guys with automatics have pulled them out and had bent ones...
    Just need to be more careful in the future
    Springfield
    2004 SVT Cobra
    So how hard is it to replace pushrods? Are there any write ups on this?
    Quote Originally Posted by drummer52910 View Post
    1. Remove coilpacks.
    2. Remove valvecovers.
    3. Remove rocker arms.
    4. Remove pushrods.
    5. Coat new pushrods in oil.
    6. Install pushrods.
    7. Install rocker arms and torque bolts to 22 ft/pounds.
    8. Install and snug bolts for valvecover.
    9. Install coilpacks.
    Hardest part is the last bolt holding on the coilpack on the passenger side. Once I got it out of there, I never put it back.
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    wow, that's easy
    Lost in Texas
    Custom Slate Blue
    99 B4C
    WERD
    I havn't had mine in since I pulled it the first time either, on either side. I'm shocked that GM thought the coils get rowdy enough under the hood to require 5 bolts each anyways
    Member tyxpx's Avatar
    Florida
    Impulse Blue
    2006 GTO
    What about the ls2 pushrods?...I've never missed 3rd and hit 1st but I have missed 3rd all together and probaly overreved it a little...Think I need to pull mine to have a looky? Any other ways of knowing if they are bent other than pulling them out?
    Springfield
    2004 SVT Cobra
    Doesnt sound to bad then. Thanks for the help
    It sounds fairly easy.
    But give yourself 3-4 hours if you haven't done it before.
    And you WILL need a deep socket 10mm and make sure you use a six-sided 8mm to remove the rocker arm studs.
    S. Florida
    98 Formula /93 Z28
    Valvetrain stock??
    +1,000,000
    I keep a bag of stock pushrods on hand just in case.
    S. Florida
    98 Formula /93 Z28
    A good 10mm gear wrench works great to get in there.
    NJ
    SGM
    1998 Trans Am WS6
    4. Remove pushrods.
    I actually did mine without even removing the coil packs. But mines a '98, so it has perimeter valve cover bolts, and you don't need to remove the coils to gain access to them.
    I noticed that you left out the part about getting the engine at Top Dead Center before tightening the rocker arm bolts to 22 ft/lbs.
    According to the Haynes manual:
    Rotate crank until #1 piston is at TDC, compression stroke.
    Tighten intake valve rocker arms for cylinders 1,3,4, and 5.
    Tighten exhaust valve rocker ams for cylinders 1,2,7, and 8.
    Rotate crankshaft 360 degrees.
    Tighten intake valve rocker arms for cylindes 2,6,7, and 8.
    Tighten exhaust valve rocker arms cylinders 3,4,5, and 6.
    Did you forget to mention that part or is it just unnecessary??
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by Wesman View Post
    I havn't ever bothered to do that. I don't have double springs or anything though. If your springs are really stiff I could see reasoning behind it, but with stock springs I wouldn't consider it necessary. Won't hurt anything though, won't add more than 5 minutes to the job at most. Don't think I'm telling anyone not to do it though. Nobody listen to me!
  1. push rods are in, now what?
    By freddy_caprice in forum Internal Engine
    Last Post: 07-17-2011, 02:24 PM
  2. bent push rods
    By mike ciba in forum Internal Engine
    Last Post: 08-17-2010, 12:48 PM
  3. Help Push Rods
    By ls1transam312 in forum General Help
    Last Post: 02-11-2010, 02:55 PM
  4. Bent push rods (in need)
    By blackhawk01 in forum Internal Engine
    Last Post: 11-13-2007, 05:09 PM
  5. WTB Comp Cam 7.35 Push Rods
    By John Junkins in forum Parts Wanted / Trade
    Last Post: 02-04-2006, 06:07 AM
