Thread: Help Push Rods
02-07-2010, 07:33 PM #1
Help Push Rods
I just bought a comp cam the duration at .050" lift is 224/230 (int./exh.) lift with 1.7 rockers is .581"/.588" (int./exh.) on 114 lsa. I need to know if I need different push rods. If someone could help me out and let me know it would be great.
02-07-2010, 08:08 PM #2Slow'er'Ass
- Thornton, CO
Only way to know....is to measure.
You likely don't, but at minimum you will want hardened pushrods and upgraded valvesprings.2008 Trailblazer SS
Lowered, HID's, tinted.
02-09-2010, 07:53 AM #3
7.4's will do you fine. Like said earlier Chromoly pushrods and new valve springs would be wise to change also.
02-10-2010, 07:50 AM #4
I did buy new valve springs, and i was going to upgrade my push rods, I was just needing to know if I could buy standard length.
02-10-2010, 08:02 AM #5
Standard will do you fine
02-10-2010, 08:09 AM #6
I have seen the aftermarket cams base circle smaller the stock and it mite take a 7.425 instead of 7.4 but measure and know for a fact.
02-11-2010, 02:55 PM #7
Have you made any changes to your Cylinder Heads?? Lifters??? If not the guys responses are correct: 7.4 or 7.425 hardened chromoly + springs. 7.4 may increase the valvetrain noise slightly, 7.425 should be right on with the different base circle of Comp Cams WITH XER lobes.........
Help: Push rods and springs
By WhatUpWhatUp in forum Internal EngineReplies: 3Last Post: 02-17-2012, 03:49 PM -
push rods are in, now what?
By freddy_caprice in forum Internal EngineReplies: 2Last Post: 07-17-2011, 02:24 PM -
bent push rods
By mike ciba in forum Internal EngineReplies: 5Last Post: 08-17-2010, 12:48 PM -
Heads cam push rods.....
By Rickys S/C Z28 in forum Parts For Sale / TradeReplies: 9Last Post: 05-01-2009, 08:59 AM -
Bent push rods (in need)
By blackhawk01 in forum Internal EngineReplies: 4Last Post: 11-13-2007, 05:09 PM
