Thread: Push rods and springs
02-16-2012, 10:41 PM #1
I found some cheap ls6 yellow springs that come with 243 heads. Are the springs any good or should I swap them ? And are the ls6 push rods any good or should I swap them to ?
02-17-2012, 06:10 AM #2
If they are used I wouldn't bother. Probably already lost 50% of their usefull tension life.
02-17-2012, 08:28 AM #3Old Member, New Username
- Aug 2011
- Browns Mills NJ
Green- 1995 Z28 w/ LS1 Swap
As long as your running stock components you should be fine, if you cam the car you'll have to upgrade both the pushrods and springs.
Heads/Cam/Intake/Stall.
404 Rwhp uncorrected @ 6400
02-17-2012, 03:49 PM #4
No everything new, coming off a vette. Yeah I plan on swapping cam when I do the heads, so I guess I'll just get the 243's!I want to port and polish the heads, how much should I take off ? going with TorquerV2.
push rods are in, now what?
By freddy_caprice in forum Internal EngineReplies: 2Last Post: 07-17-2011, 02:24 PM -
Help Push Rods
By ls1transam312 in forum General HelpReplies: 6Last Post: 02-11-2010, 02:55 PM -
Heads cam push rods.....
By Rickys S/C Z28 in forum Parts For Sale / TradeReplies: 9Last Post: 05-01-2009, 08:59 AM -
Bent push rods (in need)
By blackhawk01 in forum Internal EngineReplies: 4Last Post: 11-13-2007, 05:09 PM -
For Sale:L92 timing chain, oil pump , push rods, valve springs
By sickspd in forum Parts For Sale / TradeReplies: 2Last Post: 04-17-2007, 04:53 AM
