Thread: bent push rods
    Jul 2010
    chicago
    98 corvette
    bent push rods
    put in a cam from custom cams .050 duration 218/221 lobe lift329/335 valve lift 1.7 560/570 how long of pushrods do i need
    Member TA98's Avatar
    Mar 2009
    Maryland
    calling and asking is probably the easiest and safest method of finding out
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Did you upgrade the valve springs ? You should have good valve to piston clearance. Sounds like the valves hit the pistons for some reason.
    Explain the thread title please.
    Length depends on a few things. Stock heads? Stock lifters? What has been changed?
    Measure....twice. Adjustable pushrod length checkers are cheap.
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Seriously dude WTF? Please explain your title. How can you put a cam into a car and not know what kinda rods/springs you need?
    "Life is to short to drive a slow car"
    Gone but not forgoten: 1998 Pontiac Trans Am M6 "The Black Bandit"
    Bought- 11-18-05
    Sold- 10-14-08
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    this should be a two step process
    1. call and see what the manufacturer recommends
    2. get a pushrod length checker and check
    if the rods are bend..chances are they aren't the hardened ones..which sounds like you are running stock pushrods ?
    as too why you kissed the valve ..well pushrod length will play a huge role...if the rods are a correct length..then more than likely your timing is off /not aligned correctly.
  1. push rods are in, now what?
    By freddy_caprice in forum Internal Engine
    Last Post: 07-17-2011, 02:24 PM
  2. Help Push Rods
    By ls1transam312 in forum General Help
    Last Post: 02-11-2010, 02:55 PM
  3. Bent push rods (in need)
    By blackhawk01 in forum Internal Engine
    Last Post: 11-13-2007, 05:09 PM
  4. Bent Push Rods on LS1 M6 Cars?
    By Sunset T/A in forum Internal Engine
    Last Post: 10-31-2007, 12:08 PM
  5. top fuel do use push rods KID
    By jasonisdn in forum LT1
    Last Post: 08-22-2006, 02:00 AM
