Results 1 to 17 of 17
Thread: Valve Spring Install
08-13-2007, 06:04 AM #1Simpsons Did it!!
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
What method did you guys use to change your springs? Air fitting and pressurize the cylinders, TDC method, or with the heads off the car. Doing my cam swap soon and was curious.
TSP Torquer V2 cam, ported heads,fast 90/90 combo, LT's, 3400 stall, magnaflow CB, most other bolt ons, full suspension, t-top and HID conversion
422 RWHP, 384TQ
08-13-2007, 06:26 AM #2Member
- Aug 2006
- Madrid, Iowa
red- 02 trans am ws6
Pressurize the heads, works pretty slick. but my motor was out of the car.
08-13-2007, 10:56 AM #3
What psi do you set the regulator at?
2002 Sunset Orange TransAm 6 spd.
http://www.mustangmods.com/data/1327/dadsigpic2.jpg
08-13-2007, 11:11 AM #4Simpsons Did it!!
- Mar 2007
- Minnesota
set to around 50 psi
08-13-2007, 11:26 AM #5Member
- Oct 2005
- RI
Mag Red- 2002 Vette
TDC here. I used the compressor a few years back on my daughter's Nissan, stepped out for a minute, compressor lost pressure and I came back to a little hole where the valve used to be
Ended up pulling the head.
08-13-2007, 11:37 AM #6Simpsons Did it!!
- Mar 2007
- Minnesota
When you did the TDC, did the valves drop far and did you have any probs doing it that way
08-13-2007, 05:45 PM #7Junior Member
- Jul 2007
- Kingston, Tn
Black- 1970 Convertible Corvette
Another thing I have thought about. When changing springs, is it necessary to change the valve stem seals? Going from stock style springs to double springs?
08-14-2007, 09:19 AM #8Simpsons Did it!!
- Mar 2007
- Minnesota
Can anyone else chime in about if they did their springs the TDC way. JUst curious if there were any problems.
08-14-2007, 04:08 PM #9Member
- Oct 2005
- RI
Mag Red- 2002 Vette
The valves will drop about 1/4" or less. No problem. Only two issues I can think of, one is making sure piston is at top (I was fortunate enough to have a boroscope to confirm), second is don't whack the valve stem to loosen a stuck lock or you could damage the valve. Other than that, works great.
One other method I have used many times, get a length of 1/4" nylon braided soft rope. Feed through spark plug hole into piston, rotate crank until it stops, rope is up against valves and will hold them in place for the change. Once done, rotate crank back, pull rope and do next cylinder. Very old school method, but it works well and no risk of dropping a valve.
08-14-2007, 04:41 PM #10
08-14-2007, 04:50 PM #11Member
- Oct 2005
- RI
Mag Red- 2002 Vette
08-14-2007, 04:52 PM #12
08-24-2007, 11:57 AM #13SOM BTCH
- Apr 2006
- East Palestine, OH - USA
SOM- 2002 Chevrolet Camaro Z28
i prefer the TDC method.
08-24-2007, 03:55 PM #14
i filled the cyls with air when i did my double springs on my 5.0, and as long as you put the fitting in correctly and have an air compressor that holds plenty of air it works great. in fact i think i left the fitting in one of the cyls over night and it was fine. never came close to dropping a valve.
08-24-2007, 03:57 PM #15
08-24-2007, 03:58 PM #16
one major important tip about the air method is make sure you have at least 90psi going into the cyl. the more the better. i'd be really nervous about doing that job with only 50psi holding the valves closed.
08-24-2007, 05:16 PM #17
Heck dude, I just did the rope method and purchased the new Crane valve spring compressor and finished the job in roughly 3 hours!! Easy, quick and fast!!!
Question: Valve Spring Kit
By badboy10 in forum Internal EngineReplies: 3Last Post: 02-19-2014, 08:01 PM -
WTB: Valve Spring install tool
By JehalinTA in forum Parts Wanted / TradeReplies: 0Last Post: 06-16-2011, 07:52 AM -
By JehalinTA in forum Parts For Sale / TradeReplies: 0Last Post: 06-16-2011, 07:40 AM -
JEGS stud mount valve spr. compresor vs. Speeds valve spring
By JehalinTA in forum Internal EngineReplies: 0Last Post: 05-30-2011, 05:16 AM -
valve spring help
By iluvls1rails in forum Internal EngineReplies: 3Last Post: 02-01-2010, 10:27 AM
