    Renns badboy10's Avatar
    Oct 2009
    Eagle Pass, Austin TX
    2002 Camaro SS
    Valve Spring Kit
    Im looking into buying a valve spring kit, I got a little lost when it says 7 degree locks. What exactly does that mean?
    Coral Springs, Fl
    Sunset Orange Metalic
    Each valve spring has two lock that hold it in place top the valve. Depending on the retainer, different locks are needed. In most cases where a different lock is necessary the springs will most likely include new locks. Factory retainers and most basic aftermarket ls springs use 7 degree locks.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    The locks are like a two piece wedge and the angle of the wedge or locks is measured in degrees. I tougher the springs and keepers the larger the angle so many high performance springs come with 10 degree locks for added strength at higher RPM's
    Oct 2009
    2002 Camaro SS
    Valve Spring Kit
    Ok thx
  1. JEGS stud mount valve spr. compresor vs. Speeds valve spring
    By JehalinTA in forum Internal Engine
    Last Post: 05-30-2011, 05:16 AM
  2. Valve Spring Help
    By vestalpaul in forum Internal Engine
    Last Post: 05-20-2011, 01:38 AM
  3. valve spring help
    By ls1wallen in forum Internal Engine
    Last Post: 01-30-2011, 04:44 PM
  4. valve spring help
    By iluvls1rails in forum Internal Engine
    Last Post: 02-01-2010, 10:27 AM
  5. valve spring
    By Dantees in forum General Help
    Last Post: 11-07-2005, 07:23 PM
