Thread: valve spring help
01-30-2010, 02:18 PM #1Junior Member
- Jan 2010
- arizona
red- 2003
valve spring help
im changing my valve springs on my 5.3 i bought the springs for the cam i have.when i went to set them up the manufacture said the installed ht. should be 1.795 they measured to be.10 thosandths more in these heads , they supplied a 15 thousandths shim the question is will this work? will it make the seat pressure more which is 130lbs at 1.795 in height so pinching it 5 thousandths more should be ok ?or should i get a 10 thousandths shim ????????
02-01-2010, 07:06 AM #2
Your seat pressure will be alittle higher, but aslong as your not at coil bind at your cam's max lift it will be fine
02-01-2010, 10:12 AM #3Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
You want to be .050-.060 from coil bind ideally.
02-01-2010, 10:27 AM #4
Question: Valve Spring Kit
By badboy10 in forum Internal EngineReplies: 3Last Post: 02-19-2014, 08:01 PM -
JEGS stud mount valve spr. compresor vs. Speeds valve spring
By JehalinTA in forum Internal EngineReplies: 0Last Post: 05-30-2011, 05:16 AM -
Valve Spring Help
By vestalpaul in forum Internal EngineReplies: 1Last Post: 05-20-2011, 01:38 AM -
valve spring help
By ls1wallen in forum Internal EngineReplies: 10Last Post: 01-30-2011, 04:44 PM -
valve spring
By Dantees in forum General HelpReplies: 0Last Post: 11-07-2005, 07:23 PM
