Results 1 to 11 of 11
    texfire
    Guest
    Tach Output Wire???
    i'm trying to find the tach output wire on my '99 C5. Im hooking up a nitros works system, and thats the only wire I have left to hook up. Not sure where to find it. Its for my window switch...Any help would be great..
    Warminster, PA
    Red Connector on PCM, pin 10, White Wire
    texfire
    Guest
    My pcm has no number 10 wire on it. The only white wire is the number 3
    Senior Member MadSeason's Avatar
    Indiana
    Should be the white wire unless it differers from the fbody
    quicky06
    Guest
    well take a volt meter and put one lead on the body and the other on the wire and have somone rev it up see what happens
    Mar 2009
    rockford,il
    blk
    2000 camaro ss
    ok i hooked a tach up 2 the #10 pin white wire in my 2000 ss and my tach if off big time what did i do wrong????? please pm me
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by fastass2000 View Post
    you have to set the tach for 4 cylinder reading.
    Mar 2009
    rockford,il
    blk
    2000 camaro ss
    hey thanks bud i new i 4 got something thanks man!!!
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    check this out. i know you dont have an f-body but this should help
    http://www.installuniversity.com/ins...sity/index.htm
    orlando, fl
    2014 camaro 2ss/rs
    actually this thread is from 2005 and got revived. i hope the OP got his answer.
    Feb 2006
    Stock
    2002 Camaro
    i didnt even notice that
  1. Rca output
    By slpws6ta in forum GTO
    Last Post: 10-05-2009, 08:05 PM
  2. Question: tach out put wire
    By butchjr15 in forum General Help
    Last Post: 05-20-2009, 07:49 AM
  3. Help: Tach output wire
    By butchjr15 in forum GTO
    Last Post: 05-17-2009, 05:58 PM
  4. Tach Wire
    By tims02 in forum Corvette
    Last Post: 09-03-2008, 03:33 AM
  5. Tach Wire?????????
    By CamaroCrazyChris in forum General Help
    Last Post: 04-23-2006, 05:42 PM
