Results 1 to 10 of 10
Thread: Tach Wire?????????
04-20-2006, 08:49 PM #1Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
Tach Wire?????????
Ok, I am pretty knowlodgable when it comes to my F-Bodies, and I consider myself almost expert with the electrical side of things but for the life of me I cant find my tach wire behind the dash!!!! I know where it is at the PCM but I have my dash out right now and there is NO WHITE TACH WIRE going to the gauge cluster, The book says its white all the way to the tach, but it lies I tell you.
Any help would be appreciated,
Thanks a ton guys!!
04-21-2006, 05:13 AM #2Member
- maine
black- 2000 ws6
considering the guages plug into a socket there wouldnt be a wire runing the the tach, so maybe check the wires leading into that socket and tap off there... but maybe this is just obvious to you. cant think of anything else....
04-21-2006, 11:39 AM #3Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
That was where I was looking for the wire, I took apart the clust to see if I could trace the embedded circuit to the appropriate wire terminal were it would plug into but that did not help. I finally just gave in a bit and ran the wire to the BCM, I should have just saved myself 2 hours of work and did that in the first place but I seem to be hard headed.
04-23-2006, 05:20 AM #4Member
- maine
black- 2000 ws6
shitty... so did it end up working anyway?
04-23-2006, 10:53 AM #5Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
Yes it did, Thanks
04-23-2006, 11:39 AM #6
I did this on my last f-body (98)-had to pull the entire dash forward enough to get behind it, big hassle, and if I remember right it was a white wire. Don't have an updated manual for my 02 so I don't know if that's changed or not.
04-23-2006, 12:36 PM #7SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
I couldn't find mine when I installed remote start, I ran it to the bcm too, it's just as easy if not easier
04-23-2006, 12:49 PM #8
Yeah-my way was a PITA,pulling the entire dash is a big hassle. I pulled forward enough to get to the wire,the manual shows the connector view for the gauge cluster, the white wire was easy to find and connect to. Was hooking up a remote starter also,didn't feel comfortable hooking onto the coil pack as the manual showed several tach leads and no reassurance that I would be frying the computer. If remember right I didn't want to hook into the BCM either ,where is the tach lead there?
04-23-2006, 12:55 PM #9SUPREME member-oderator
- Nov 2005
- Lost in Texas
don't remember now what color, brown or tan I think? got the info from bulldog's website, it lists what colors they are at the BCM. I have used a fuel injector wire on an LS1 also with no problems whatsoever
04-23-2006, 04:42 PM #10Member
- Oct 2005
- St. Louis, Mo.
Black- 2002 Camaro
The manual says its a white wire all the way to the tach, but it lies I tell you. I did find that white wire going to the BCM though, from there the color is definately different. Not sure which one it was though.
no tach
By CHRISFORMULA in forum General HelpReplies: 6Last Post: 08-25-2010, 09:05 AM -
Question: tach out put wire
By butchjr15 in forum General HelpReplies: 3Last Post: 05-20-2009, 06:49 AM -
Help: Tach output wire
By butchjr15 in forum GTOReplies: 0Last Post: 05-17-2009, 04:58 PM -
Tach Output Wire???
By texfire in forum NitrousReplies: 10Last Post: 04-01-2009, 06:25 PM -
Tach Wire
By tims02 in forum CorvetteReplies: 5Last Post: 09-03-2008, 02:33 AM
