Thread: tach out put wire
05-17-2009, 01:44 PM #1Junior Member
- May 2009
- pa
blue- 2005 gto
tach out put wire
hey guys im hooking up a shift light on my 05 gto ls2 and i cant find the tach out put wire. i was told it was pin 48 in the blue plug for the ecm. i took the plug apart and not all the pins are numbered. does anyone know what color the wire is? thanks guys
05-18-2009, 05:46 PM #2
J1 (Blue Connector) Pin #48 (Brown Wire w/red tracer) is the Tach signal
05-19-2009, 05:26 PM #3Junior Member
- May 2009
- pa
blue- 2005 gto
ok thanks. ill give it a shot.
05-20-2009, 06:49 AM #4
no tach
By CHRISFORMULA in forum General HelpReplies: 6Last Post: 08-25-2010, 09:05 AM -
Help: Tach output wire
By butchjr15 in forum GTOReplies: 0Last Post: 05-17-2009, 04:58 PM -
Tach Output Wire???
By texfire in forum NitrousReplies: 10Last Post: 04-01-2009, 06:25 PM -
Tach Wire
By tims02 in forum CorvetteReplies: 5Last Post: 09-03-2008, 02:33 AM -
Tach Wire?????????
By CamaroCrazyChris in forum General HelpReplies: 9Last Post: 04-23-2006, 04:42 PM
