    Senior Member 02ultraZ's Avatar
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Exclamation strange scary noise coming from my motor, help.
    Ok i have an '02 Z with 30k on it. It does have the piston slap. There is a new noise that has only happened twice but it sounds horrible. Each time i drove my car like 40 miles, then it sat and cooled for like 6 hours or so. It was still like 80 degrees out so it's not like it was that cold. But when i fired it up there was a whine coming from the motor. I know it was the motor. But the first time it did it I thought i was the throw out bearing for the clutch but only because of the initial sound. I was playing with the clutch and it didn't change the sound so i know it wasn't that. The sound sped up so to speak when i gave it gas. I really have no idea what the hell it is, it went away once it warmed up. Help me out guys i don't have a clue. I put 10-30w in the car perhaps the wrong oil if i have the piston slap?
    Senior Member
    Jacksonville, FL
    First thing that comes into my mind is the air pump, especially if it only happens on start up. Do a cold start and pull the AIR PUMP fuse under the hood while it's making noise and see if it stops. It'll throw a code but SES will go back off after a couple cold starts and replacing the fuse. Could also be an accessory. My car has piston slap and I run 10W-30.
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Quote Originally Posted by 2001NBMZ28 View Post
    Thanks for the idea i will try this tonight...
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    try turning the wheel to see if it gets worse.
    I was thinking power steering pump / fluid level
    00 Z28 M6 T-tops
    00 SS A4 T-tops (Sold)
    99 Corvette M6 (Sold)
    98 Z28 A4 Coupe (Sold)
    98 Z28 A4 T-tops (Sold)
    Norman, Oklahoma
    White/Black
    1999 Z28
    Those things can make some noise
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Quote Originally Posted by b.lee View Post
    I know it wasn't the power steering pump, i know that sound.
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Quote Originally Posted by Kjz99z28 View Post
    This noise changed with engine RPM's too so im not sure if it's the air pump but i will pull the fuse...
    Senior Member
    Jacksonville, FL
    Yeah, saw that in your orig post - thought it might just be increased voltage to the pump. If nothing else, pulling the fuse will eliminate the pump as the problem and won't hurt anything.
    Harrisburg, PA
    Blackety Black
    35th Anniversary SS
    Yea i didn't rule out the airpump yet because i don't know, but i was talking about the power steering whining is def. ruled out.
  1. Help: strange noise!
    By 98maro in forum Suspension and Handling
    Last Post: 05-30-2012, 07:00 PM
  2. Strange sound coming from rear end
    By dreed2 in forum General Help
    Last Post: 08-15-2009, 08:54 AM
  3. strange scary noise coming from my motor, help.
    By 02ultraZ in forum Drivetrain
    Last Post: 08-14-2007, 09:56 AM
  4. Easter is coming... strange conspiracies...
    Last Post: 03-30-2007, 12:25 PM
  5. Strange sound coming from brakes...
    By chris5 in forum General Help
    Last Post: 12-07-2005, 10:18 AM
