Thread: Loose door window....Help!!!
08-01-2007, 04:59 PM #1
When my window is down I can slide it about 2 inches in either direction (side to side or back and forth) When rolling it up I have to manually guide it in track and when up it can tilt or fall inwards towards the inside. I have seen where some wrote that a bolt had became loose in the regulator but all I can find are rivets and no bolts. I noticed when I took off the door panel at the top of the inner panel there are two bolts holding a clamp and one also has a brass looking U shaped metal piece bolted with one of the two bolts. It appears the brass piece could be broke and what has been scratching up my tint. Any Thoughts??
08-01-2007, 05:00 PM #2
Oh yea it is a 1998 z28 and drivers side.
08-03-2007, 07:55 AM #3
I had the same issue on my 97, i had a few scratches all the way up my window in the tint, finaly i took the door off and there are two "brass looking clamps that should have felt or some type of soft material on the end. If its missing it will scratch your window to shit and also let it flop back and forth. Should only be one bolt on each of them to remove, and either order them from Gm or junk yard. i went to a junkyard and picked mine up.
Its a simple fix once you get the parts.
08-03-2007, 09:41 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
Sounds like the stabilizers, could be something else going on too. Check out http://shbox.com/1/adj_window.html
08-05-2007, 01:47 PM #5
Thanks Guys, as we say in Alabama, y'all made my day. I did do a forum search but the results are listed by most current and not relevant. I looked until I couldn't see straight. Thanks again!!!
Drivers window coming loose or off track?
By SMWS6TA in forum General HelpReplies: 17Last Post: 04-09-2014, 06:24 PM -
Help: Loose driver side window?
By Mattg in forum General HelpReplies: 1Last Post: 06-11-2008, 05:45 PM -
Door window guide
By JWSmythe in forum General HelpReplies: 0Last Post: 05-24-2008, 02:35 PM -
need driver door/w window
By LS1buckey in forum Appearance SectionReplies: 2Last Post: 03-18-2008, 04:56 PM -
Window/door problems
By ixlr8nxs in forum Camaro / SSReplies: 6Last Post: 04-19-2007, 11:28 PM
