    Harmony NC
    2000 Z28
    Window/door problems
    I have noticed that if I roll the drivers window all the way down it seems to push the door panel out some. Then when I roll it back up it "pop" before it starts rolling up. Any idea what might be broken or out of alignment?
    manassas, VA
    99 z28 camaro
    i would pull off the door panel and take a look thats the only way youll find out for sure
    UberTapping Friction Pimp Anthracis's Avatar
    Omar's Tittie Taverna & Grill, Deh Rawod
    18D Cock Diesel
    1999 Z28; 98 SS #2043 RIP
    one of the window regulator bolts may be loose and when your window is down the motor is moving and thus pushes in towards the door panel causing it to move. But this is all conjecture until you remove the door panel and have a look.
    Feb 2007
    San Jose, CA
    2002 Camaro SS
    Quote Originally Posted by Anthracis View Post
    I agree.... i had a similar problem and adjusted the regulator bolts and now the window goes up and down without any problems.
    Member Corey1987's Avatar
    Greenville, NC
    1998 Z/28
    mine does the EXACT same thing, i have noticed today that if i roll mine almost all the way down, the window can move forward and back about an inch and a half, guess i just gotta take off my door panel and check.
    18D Cock Diesel
    be careful when removing the door panel. Those clips can be quite fragile.
    Chevy Power LS1RacerMan30's Avatar
    Aug 2006
    Canyon Country,California
    1995 Chevy Camaro LT1
    Yea,Mine did that same shit.I took the door panel off and it came off track and one of the bolts to the regulator came loose and fell off.So I put the bolt back in and put the window back in the crease in the window seal to line it back up and the window worked fine after that.Make sure when U re align the window use the motor to line up the bolts while holding the window straight
  1. Help: Power window hitting door?
    By CD99Firebird in forum General Help
    Last Post: 07-09-2015, 02:44 PM
  2. Door window guide
    By JWSmythe in forum General Help
    Last Post: 05-24-2008, 02:35 PM
  3. door Window outside weatherstriping
    By slikws6 in forum General Help
    Last Post: 05-10-2008, 09:47 AM
  4. need driver door/w window
    By LS1buckey in forum Appearance Section
    Last Post: 03-18-2008, 04:56 PM
  5. Loose door window....Help!!!
    By jeremy_m70 in forum General Help
    Last Post: 08-05-2007, 01:47 PM
