Results 1 to 18 of 18
    Drivers window coming loose or off track?
    Coming back from the Post Office my drivers window rolled up strange. Seems like it is fixing to come off track or something is very loose.
    It still rolls up but at the last 3 inches I have to push it out and guide it.
    I know it is not a bad motor. I know what that problem looks like.
    I've been searching and I'm not sure if this is the same issue I have but it is the only thread I've found that talks remotely in the area.
    http://ls1.com/forums/showthread.php...t=door+windows
    Any ideas before I start tearing into the door would help.
    Member My00Z28's Avatar
    Sep 2010
    Holland, MI/Lima, OH
    2000 Camaro Z28 A4
    this might not be the right picture but this same thing happened to me if yours is the same... have fun!
    site i got the diagram from!
    http://www.gmpartsdepartment.com/par...layCatalogid=0
    number 14 its called a sash channel... and you will not find it at the dealership... gm discontinued it for some reason but they make it for the passenger side! there is a guide that rides in a track that is kinda common for breaking making it so your window wont roll up properly... what i did was welded it back together and replaced the wheel with some from an 80's camaro i think! after class ill look into it alittle more again if you dont get another answer!
    Sep 2010
    2000 Camaro Z28 A4
    i cant seem to find a better picture than that but number 14 will ride in the channel on number 16 which guides your window into place what happened is the piece broke so we welded it back together when we did that it melted the plastic wheel that rides in that so i found out that the 80's camaros had those wheels in them this is what i got to replace the wheels!
    http://cgi.ebay.com/ebaymotors/1982-...8#ht_825wt_939
    So your saying it's going to be painful right!
    Ok......any guesses if the 93-97 have the same sash channel? I got access to a couple of them if they do. 98-02's are almost impossible to find around here.
    Sep 2010
    2000 Camaro Z28 A4
    Yes it sucks and yes it is the same from 93-02 I'm pretty sure...
    does it come up crooked at all??? when i had this happen the rivet popped off of the track guide... i also had #9 part snap on the door...
    Yeah it does. about the last 4 inches
    i plan on looking at it this week end, but my wife has bath room tile plans
    bathroom will be there still and won't break worse... the window on the other hand has the posability of shattering since it will be sliding back and forth inside the door when it is down...
    I know......but wife's reply was "you don't have to drive it or lower the window down. My bathroom will be done this week end or else!"
    sorry I like having You don't piss of a Panamanian woman.
    Member bobbyd's Avatar
    austin
    sorry I like having You don't piss of a Latina woman
    fixed it for you lol
    austin
    not trying to hijack this thread. I have a kinda similar problem. except what mine does is that once its all the way up you hear a clunk sound (it wants to keep on going if you hold the button) anyone had a problem like that? if so what #'s from the diagram should i be looking at.
    Sep 2010
    2000 Camaro Z28 A4
    Number 16 is where u would adjust the hight of ur window
    Quote Originally Posted by bobbyd View Post
    Mine was kinda making that sound in the beginning. So it looks like you need to open her up like me. I hope I can get to mine tomorrow.
    Orlando, FL
    Mean Black
    I had this issue and it was the roller attached to #14. the metal rod that holds it snapped out. I tried to fix it and it didnt last long. I never tried welding it. I was able to find an used one in a junk yard. If you do this yourself you need to drill out the rivets that hold the window to it. Remove the window and replace the part. I was able to find the rivets and the tool to reattach the window. If you dont have the tool you can always take it to a window repair place and they can install it back.
    Here is some pics of the part:
    This is the roller part that snaps out with the rod:
    that would be it... jay nailed it on the head... same exact thing mine was...
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Aaaaaaaaand this thread is resurrected!
    So, any ideas on where to get the sash? According to the dealer, that is my problem, but the part is not available through any of their channels. I can't seem to find it on any online shops, either.
    I had to get one from the salvage yard to get it fixed.
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Ugh... figures... Okay, cool, thanks!
  1. Drivers window
    By wicked1 in forum General Help
    Last Post: 03-17-2010, 01:43 PM
  2. Drivers Window?
    By Speed_kills_WS6 in forum General Help
    Last Post: 10-28-2009, 09:32 PM
  3. Help: Loose driver side window?
    By Mattg in forum General Help
    Last Post: 06-11-2008, 05:45 PM
  4. Loose door window....Help!!!
    By jeremy_m70 in forum General Help
    Last Post: 08-05-2007, 01:47 PM
  5. Lug bolt not coming loose..help!?!
    By Joe K. 99 Zeee!! in forum General Help
    Last Post: 01-20-2006, 07:46 AM
