Results 1 to 3 of 3
    somewhere
    A car
    Lug bolt not coming loose..help!?!
    I've been trying to hammer out a busted lug bolt. I've been using a mini-sledge and it's not budging yet. I don't want to damage anythinge else by hammering harder. Any hints??
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Can you clarify what you are doing? Is the wheel off and you are trying to remove the stud from the hub? It should drive through unless you've somehow boogered up the stud to where it wont go through the hub anymore. The best advice is to hit it like you are driving it through the hub instead of just hitting it-like hitting a baseball-you drive through it not just make contact.A big punch can sometimes help avoid damaging other things around the stud.
    somewhere
    A car
    Trying to remove the stud from the hub....but I got it out finally. Mini-sledge and a good bit of hammering did it.
  1. Drivers window coming loose or off track?
    By SMWS6TA in forum General Help
    Last Post: 04-09-2014, 06:24 PM
  2. Question: Loose
    By cowstandmoto in forum Firebird / WS6
    Last Post: 12-11-2012, 01:04 PM
  3. Center bolt to Perimeter bolt Heads, Coil Mounting help
    By juiced99ws6 in forum Internal Engine
    Last Post: 03-30-2007, 11:38 PM
  4. when u got nothing to loose
    By ss~zoso~ss in forum Multimedia Section
    Last Post: 01-29-2007, 02:38 PM
  5. crankshaft pulley bolt loose
    By jerrypc in forum General Help
    Last Post: 07-09-2006, 10:46 AM
