Results 1 to 2 of 2
Thread: crankshaft pulley bolt loose
07-08-2006, 04:22 PM #1
- Jul 2006
- delaware
black- 1999 corvette
i found out today that my crankshaft pulley bolt is loose. can anyone recommend a tool for tightening this thing up? a standard 15/16" socket doesn't give me enough clearance; the rack and pinion is in the way. Thanks for your help.
07-09-2006, 10:46 AM #2
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
a 3" ext. and a 24mm socket should work. use some blue lock tight. is it a stick or auto? if its an auto, you're gonna have to find a way to keep the motor from turning. if its a stick, put it in 4th and put the ebrake on. and tighten away. did u recently remove it? its best to buy a new bolt..they're no more than 5-6 bucks.
Crankshaft pulley wobble. What to do?
By SiskMan in forum General HelpReplies: 25Last Post: 10-27-2014, 08:40 AM -
how to get crankshaft pulley bolt off?
By JehalinTA in forum Internal EngineReplies: 12Last Post: 06-19-2011, 07:14 AM -
torx bolt on the a/c pulley
By redbird555 in forum General HelpReplies: 8Last Post: 06-19-2010, 04:18 PM -
What Tap for the CrankShaft Balancer Bolt
By 2000TransAm400HP in forum General HelpReplies: 8Last Post: 07-07-2007, 07:55 PM -
Lug bolt not coming loose..help!?!
By Joe K. 99 Zeee!! in forum General HelpReplies: 2Last Post: 01-20-2006, 07:46 AM
