Page 1 of 4 1234 LastLast
Results 1 to 20 of 68
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    What cams is everybody running
    JUst curious, but what is everyone running for a cam, and if you are, what size and why did you choose that one.
    Arkansas
    99 Trans Am
    I am running a 230-236 dur. 580-590 lift on a 114 LSA. I chose mine because I was willing to sacrifice some driveability for a larger cam and the cam was ground the way it was because I wanted a cam that would do well with my bottle.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    vinci 099
    DUR @ .004" 294* / 302*
    DUR @ .050" 232*/ 240*
    LIFT .551/.551
    OVERLAP 64*
    LSA 117*
    i chose it because it fits my needs. big enough for my 408 without the tuning hassles associated with close LSA. i may sacrifice a little peak power, but i'll get a longer rpm range of usage.
    Indianapolis, IN
    All Black
    83, 87, 02 All WS6 T/As
    I'm running a cam... a stock cam.. lol.
    -Geno
    1983 Black WS6 "WindCharger"
    1987 Black WS6 "WS87"
    Sold the other four f-bodies
    houston
    2001 z28
    224/230 .585 .592 114. it seemed to be a perfect cam for my dd 6.0. not too big or small.
    DFW
    '18 CTS-V
    '13 ZL1
    currently runnning:
    Comp Cams 224/224 .581/.581 @112
    stepping upto (in my posession) already:
    TSP 231/237 .595/.598 @112+2
    2013 ZL1: °°590rwhp/576rwtq°°
    228/228 .588/.588 on a 114 LSA
    Member chieftransam's Avatar
    Germany
    Blue
    2001 Pontiac Trans Am M6
    i also have the 224/224 .581/.581 112lsa
    Minnesota
    83 Z28 new project
    maybe if more people post up, the mod gods that be might make this a sticky for others to savor over.
    NC
    1998Z28
    I run a MS4 cam. But I can't recommend anything for you because you need your Signature filled out even if your stock so we can see how your cars setup.
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    MS4 here too baby!!!
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    248/254 629/622 113
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    MS3 was going to get MS4 but got scared when I heard a few things about piston/valve clearance and didnt want to risk it. On 114 LSa for Nitrous use.
    My Toy 00 Z28 1SC A4 - MS3 cam with supporting valvetrain, Milled LS6 heads, LS7 lifters, , ARP rod and mains, All free mods, pacesetters, True duals, moser 9 with 4.11's and Detroit Locker, Vig 3600 tuned, tubular SFC,adj PHR, LCA, adj TA, PHR reloc, LCA reloc. all with poly bushings, ZR1's and Nitto DR's (315).
    My other toy 05 GTO LS2 M6- Comp XR269HR cam, 918's, hardened pushrods, Dart Pro 1's, pacesetters, X-pipe, flowmaster 1 chambers, TSP oil pump, Tick master cylinder. Pedders RR bushings, end links, SB bushings, tie rods and strut mounts, total performance poly F&R bushings. Polk DVC 12", Infinity Kappa 6.5 component and 6x9's with corresponding amps.
    Her toy 77 F100-6.6/c6. All original (for now)
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    Comp Cams 224/224 581/.581 114 lsa.
    i wanted a good mid range cam that has decent manners.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Kansas City
    Onyx Black
    2002 Z28 Camaro M6
    What kind of gas mileage are you guys getting. I want to get a cam down the road but as this is my daily driver I don't want to go to extreme. I have heard that 224/224 is a good starter? I want to run nitrous down the road but don't want my cam to only work well while on the spray. My car is stock now minus the y-pipe dumped over the rear axle, and the free ram air mod.
    Cant duck it fuck it theslow00's Avatar
    casa grande az
    BLUE
    00 TRANS AM
    a lot of ppl run the 224 cam it is a great starter cam, lots of torque.
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by nhraformula View Post
    Quote Originally Posted by KansasZ28 View Post
    Quote Originally Posted by theslow00 View Post
    here is what im putting down w/my 224...
    Mods: SLP Lid, SLP Bellow, Comp 224, Patriot Stage II heads (59cc), FAST90/90 (ported), LT's/ORY, SLP LM, HP Tune...
    Kansas City
    Onyx Black
    2002 Z28 Camaro M6
    Those numbers look nice, I would be on stock LS6 Intake and stock heads... so I doubt I would be anywhere near those numbers. Did gas mileage drop significantly?
    Member fxgs's Avatar
    Camp Hill, Pa
    Onyx Black
    2002 SLP Camaro SS
    Comp Cams 223/227 .637/.640 110 LSA
    RI
    Mag Red
    2002 Vette
    I am running the Vinci 056, 216/224 0.551/0.551 115 LSA. Nice sleeper cam, idles good and isn't a bear in traffic. Nice flat power curve. I would have liked a cam with more lope to it just because I love the sound, but this little cam has met my needs thus far. I was also trying not to go too wild so my wife would still drive the car.
  1. Running rough if running at all help
    By ichliebecamaro in forum LT1
    Last Post: 01-25-2010, 10:54 AM
  2. cams
    By woodywoody in forum Internal Engine
    Last Post: 02-05-2009, 06:43 PM
  3. Question: Should I buy GTO w/Cams?
    By bobbyv in forum GTO
    Last Post: 11-08-2008, 06:28 PM
  4. Comp Cams New Thumper Cams
    By Z ROADSTER in forum Internal Engine
    Last Post: 08-27-2007, 12:39 PM
  5. cams ????
    By Ridinfilthy in forum Camaro / SS
    Last Post: 02-04-2007, 05:10 PM
