    Member Z ROADSTER's Avatar
    Shreveport,Louisiana .USA
    PEWTER
    2002 Z/28 VERT.
    Comp Cams New Thumper Cams
    Does anyone know when Comp Cams will be offering the new THUMPER cam series for the Gen 111 LS1 motors ?
    The best sounding cam on the market. Look for Crane to copy the Thumper series cause its bitchin !
    RI
    Mag Red
    2002 Vette
    Why would Crane copy these when they had their own series of big cams out for the Gen III motor over a year ago. Just got in a Comp cam to install in a friends car, no pin in the cam. Great quality control there at Comp. Called their tech support, the guy tells us to pull the pin from the old cam and install in the new. This is a case hardened pressed in pin, so they even had incompetent people on tech support. I'm not impressed
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    Quote Originally Posted by Z ROADSTER View Post
    this cam is not even out and you call it the best sounding cam, lol
    sounding good doesnt mean it will perform well.
    the cam you speak about is unproven, why would crane copy it?
    a few bolt ons, 379 rwhp
    11.96 @113.25
    PEWTER
    2002 Z/28 VERT.
    Quote Originally Posted by nhraformula View Post
    GO TO ( www.compcams.com ) & inquire about the NEW Thumper Cam Series !
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    if you look at the specs, you'll see why they'll never make them for any computer controlled engine.
    http://www.compperformancegroupstore...ry_Code=Thumpr
    now, if you want to use that cam, convert your LS1 to carb and have at it. the Thumpr Cams are specifically targeted for the older musclecars.
    Dec 2002
    n/w chicago
    first off, they dont even make one for an ls1,
    Thumprâ„¢ Cam Specs and Part Numbers
    Big Block Chevrolet Small Block Ford Windsor
    Small Block Chevy 55-98' Small Block Chrysler
    Small Block Chevy 87-98' (w/factory roller)
    secondly, just because it cackles hard means nothing.
    you can order any cam with a low LSA and get it to cackle like it does in the sound clip.
    Marylandistan
    2001 Trans Am (sold)
    Lmao!
  1. Thumpr comp cams
    By 99LS1 in forum Internal Engine
    Last Post: 04-11-2012, 07:53 PM
  2. Comp Cams
    By tg580 in forum General Help
    Last Post: 04-22-2010, 09:47 AM
  3. Question: Comp Thumper cams
    By turbodarryl in forum Internal Engine
    Last Post: 01-20-2009, 11:15 AM
  4. F/S comp cams 216/588 114+2
    By gen3performance in forum Parts For Sale / Trade
    Last Post: 06-23-2006, 11:54 AM
  5. Comp Cams 7.375 pushrods
    By TSLS1TA in forum Parts For Sale / Trade
    Last Post: 06-04-2006, 07:43 PM
