Results 1 to 14 of 14
Thread: Comp Cams
    Member tg580's Avatar
    niles, mi
    Comp Cams
    Anyone tried a 54-426-11 from Comp Cams? Trying to find a good cam. I am going with an LS6 intake, pacesetter long tube headers and off road y pipe, 3200 stall and 3.73 gears.
    niles, mi
    ttt
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    could you post the lift and duration/lsa most of us don't know cam companies code names.
    Jun 2009
    coon rapids, MN
    2000TA
    have you tried camquest6 ? you can down load it from compcams.
    LSX Tuner/Mechanic
    Atlanta
    purple
    2057 Bugatti
    Check your other thread, and let Speed Inc spec one for you. Good luck
    Junior Member st_cspeer's Avatar
    Oct 2009
    Waco, Tx
    Artic White
    2002 Camaro Z28
    Yes, I have this particular cam!!! For daily driver is not a bad choice, will give you some "lope" sounds super hot if you have a cut-out. I would maybe go little larger maybe the 281, but u would have to tune it right away. The 275 can run without a tune but not very well. I gained as much from the tune as I did the cam. Im a auto without a stall and this put me at 368 rear wheel HP.
    Oct 2009
    Waco, Tx
    Artic White
    2002 Camaro Z28
    Oh and for everyone it this cam is 222/224/112
    Bay Area
    my highbeams
    Quote Originally Posted by st_cspeer View Post
    If yours was the 222/224 what was the lsa? Can't imagine you would have a 112 w/ a stock stall, other mods for that 368hp?
    stalled car def go bigger
    Omaha, NE
    2000 Z28 Camaro
    I'd go a bit bigger, unless you have to worry about emissions?
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by allbaugh_04 View Post
    Agreed. I have a 228/232 and it has excellent street manners. I actually wish I went bigger now.
    2018 Tahoe - Silver - OEM
    Oct 2009
    Waco, Tx
    Artic White
    2002 Camaro Z28
    [QUOTE=c5z28;2309299]If yours was the 222/224 what was the lsa? Can't imagine you would have a 112 w/ a stock stall, other mods for that 368hp?
    MY Camaro Mod's
    Performance
    1.LS6 Intake
    2.SLP Cold Air Induction package P/N: 21033
    3.SLP Air Temperature Module P/N: 63012
    4.SLP Smooth Bezel P/N: 23065
    5.SLP Mass Air Flow Sensor (screen removed) P/N: 20362
    6.SLP Air Box Lid P/N: 21045
    7.SLP 160degree Thermostat P/N: 100223
    8.Ported Throttle Body
    9.Pacesetter Long Tube Header (ceramic coated)
    10.Cut-out/Muffler bypass (with Electic McCord Power Plate)
    11.3 Inch Exhaust
    12.Comp Cam XR275HR-12
    13.Comp Cam Push Rods
    14.Comp Cam Valve Springs
    15.JP Performance Double Roller Timing Gear Set
    16.Mesier High Volume Oil Pump
    Oh and 17. Brand X Dry Nitrous Kit with Progressive contoller.
    (hit 478 rwhp when I decide to spray)
    Oct 2009
    Waco, Tx
    Artic White
    2002 Camaro Z28
    just to clarify, I do have 222/224/ lsa 112 on the stock stall. Planning on going to 3200 to a 3600 stall soon.
    Bay Area
    my highbeams
    [quote=st_cspeer;2310531]
    How the hell does that thing drive w/ a 112? Where does it idle at? push through the brakes etc?
    Arizona
    Well the cam isn't that big considering the duration numbers. 222/224 at .050 is pretty tame. 112 isn't really that tight either.
    It really depends on how much advance is ground into the camshaft too. With 4-6 degrees advance ground in, it will produce more vacuum and have less chop at idle, with a better torque curve down low. With good tuning it could be made to drive on the stock converter, although I personally wouldn't do it.
    Without much advance ground in, the cam becomes more choppy, less vacuum, harder to idle while in gear.
    Most of comps stuff, especially their off the shelf cams are ground with 4 degrees of advance right off the bat. This can be fudged around on the install while degreeing the cam as well.
    I'm willing to bet with 112 lsa the cam already has a 108 icl. So it's not going to be super choppy, just noticable. Probably will idle around and drive okay.
  1. Thumpr comp cams
    By 99LS1 in forum Internal Engine
    Last Post: 04-11-2012, 07:53 PM
  2. Comp cams 918 valvesprings
    By Rk ws6 in forum Internal Engine
    Last Post: 09-06-2009, 12:58 AM
  3. Comp Cams New Thumper Cams
    By Z ROADSTER in forum Internal Engine
    Last Post: 08-27-2007, 12:39 PM
  4. F/S comp cams 216/588 114+2
    By gen3performance in forum Parts For Sale / Trade
    Last Post: 06-23-2006, 11:54 AM
  5. comp cams xr281 hr 12
    By golem72 in forum Parts For Sale / Trade
    Last Post: 10-21-2005, 04:28 AM
