Thread: Comp cams 918 valvesprings
09-02-2009, 06:52 PM #1
so i just ordered my comp cams 918 beehive valve springs and was wondering if anything... i mean ANYTHING is needed other the just the valve springs to install them on my stock ls1 heads..... thanks
09-03-2009, 09:06 AM #2
Are you just replacing springs? Why?
Valve seals while your in there, maybe Ti retainers, push rods, and have the Speed Inc valve spring tool really... really helps.
09-03-2009, 05:31 PM #3
higher rpm so i can run 4th out across the 1320 since i now have 411s and to keep my valves from floating....
09-04-2009, 04:18 AM #4
Bill has the valve spring tool you need. we modded one to work better in tight areas. you'll need a way to hold the valves up when you take the springs off, we use a compression tester hose hooked to constant air
if you want to come up to Mercersburg when you get your springs we can have them in pretty quick.
09-04-2009, 03:49 PM #5
It would be nice to find a set of titanium retainers & locks, but will work without.
09-04-2009, 09:52 PM #6
09-06-2009, 12:58 AM #7
Thanks Mark,Bill,beaver,and branden we got the valve springs in and done tonight well i should say today lol its 5am and i need sleep.... peace
Comp Cams
By tg580 in forum General HelpReplies: 13Last Post: 04-22-2010, 09:47 AM -
Comp Cams New Thumper Cams
By Z ROADSTER in forum Internal EngineReplies: 6Last Post: 08-27-2007, 12:39 PM -
Comp Cams Valvesprings / Titanium Retainers
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 04-10-2007, 06:50 PM -
F/S comp cams 216/588 114+2
By gen3performance in forum Parts For Sale / TradeReplies: 1Last Post: 06-23-2006, 11:54 AM -
FS:Comp 921 dual valvesprings
By rico750sxi in forum Parts For Sale / TradeReplies: 3Last Post: 03-18-2006, 05:40 AM
