Thread: cams ????
02-03-2007, 03:39 PM #1in doubt tach it out!!
- Feb 2007
- Ft.pierce,fl
BADASSZ28
cams ????
i bought a comp 2220224 566568 cam and was wondering what every one else was running with the cam and stock heads any help would be appreciated
02-03-2007, 06:09 PM #2Just me
- Nov 2006
- Broken Arrow, OK
Do you mean that you got a 220/224 566/568 cam? What LSA is it as well, probably a 112 or 114. What other mods do you have, we need more details about your setup to help you out here. Also, are you a auto or manual tranny?
02-04-2007, 08:00 AM #3in doubt tach it out!!
- Feb 2007
- Ft.pierce,fl
BADASSZ28
112 lsa auto , 3.73, slp catback , pacesetter lt, tc1 3000, nitto's, iwas hoping for around 375 rwhp and maybe 12.20's what do you think i hear that is a fairly mild cam but i think it is a good cam i will eventually get the heads ported or just buy new ones not sure yet??
02-04-2007, 08:23 AM #4Just me
- Nov 2006
- Broken Arrow, OK
I see tuning and LS6 intake missing from your setup, did you forget to mention them or do you not have them currently. I could see you running low 12s assuming you can 60' well, but I would see you more around the 360RWHP range. Don't worry about dyno #s from an auto though
02-04-2007, 04:52 PM #5in doubt tach it out!!
- Feb 2007
- Ft.pierce,fl
BADASSZ28
aight thanks man i will have a stock manifold for a little while but i will have it tuned on the dyno when installed!!
02-04-2007, 05:10 PM #6
it will be close but i don't think you will see the 375 that you are hoping for. it's a little smaller than the 224 that i currently have. pre heads and ls6 intake i was sitting at 366rhp/356rtq, and i have an m6...get all the work completed and done, and post up your numbers. i'm thinking between 355-365 rwhp for you...
2013 ZL1: °°590rwhp/576rwtq°°
Cams
By navyLS1 in forum Internal EngineReplies: 7Last Post: 11-03-2009, 10:34 AM -
Question: CAMS
By 99yellowz28 in forum Internal EngineReplies: 9Last Post: 07-20-2009, 11:56 AM -
Looking at some cams.
By RyanJM in forum Internal EngineReplies: 4Last Post: 03-08-2009, 06:56 AM -
TSP MS3 and MS4 Cams?
By Sunset T/A in forum Internal EngineReplies: 22Last Post: 09-27-2007, 10:14 AM -
Comp Cams New Thumper Cams
By Z ROADSTER in forum Internal EngineReplies: 6Last Post: 08-27-2007, 12:39 PM
