Results 1 to 11 of 11
07-29-2007, 12:05 PM #1boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
how to get more power from stock heads
i have heard that you can make more power getting your stock heads reworked than buying aftermarket. is this true? if so, what specs would a machine shop have to be told?
07-29-2007, 02:31 PM #2
most of the aftermarket places are using stock heads and porting them. AFR and the new Patriot heads are new heads.
07-29-2007, 05:59 PM #3boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
07-29-2007, 06:02 PM #4Member
- May 2007
- houston
black- 2001 z28
id get them done somewhere that is familiar with ls1 stuff.
07-29-2007, 06:07 PM #5boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
07-29-2007, 06:09 PM #6Member
- May 2007
- houston
black- 2001 z28
why not go with patriot, you can tell them what you want and hell sell you only what you need. and youll get a good price, plus youll get better flow than stock ported.
07-29-2007, 06:13 PM #7boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
07-29-2007, 06:39 PM #8
patriot sells ported stock heads.
to answer semperfiws6 question is you can try and go into a machine shop and tell them to port your heads to 224cc intake runners, 80cc exhaust runners and make your chambers 63cc. whether they can do that and have it flow correctly is up in the air.Last edited by mrr23; 07-29-2007 at 06:49 PM.
07-30-2007, 03:10 AM #9boycott wal-mart
- Jan 2007
- S. Carolina
silver- 98 T/A WS6
07-30-2007, 09:14 PM #10
08-01-2007, 09:12 PM #11
how much hp do the stage II Patriots give you over stock?
Question: what cam and heads should i get for most power
By aleonard in forum Internal EngineReplies: 2Last Post: 06-07-2010, 08:06 AM -
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
New Heads or Port/Polish Stock Heads?
By Black02LS1 in forum Internal EngineReplies: 32Last Post: 06-22-2007, 11:29 PM -
New heads or Port/polish Stock Heads?
By Black02LS1 in forum Western MembersReplies: 0Last Post: 05-20-2007, 09:11 PM -
LS6 heads/cam swap how much power
By FastRegalWE2 in forum Internal EngineReplies: 9Last Post: 10-16-2005, 03:40 PM
