Results 1 to 11 of 11
    Junior Member hutcher04's Avatar
    Indianapolis, Indiana
    black with silver
    2001 pontiac trans am ws6
    Question AFR heads VS. Ported and beefed up stock heads.
    i need the pros and cons for each decision such as to just buy the new $2300 AFR heads or just port and beef up stock heads.
    Member squirlnutz's Avatar
    oklahoma
    2000 trans am
    Quote Originally Posted by hutcher04 View Post
    Why only AFR aftermarket heads ?
    black with silver
    juat specifc reason really just ones i like why?
    oklahoma
    2000 trans am
    I think TrickFlow has the best flowing LS head. I could be wrong, but I think they give more piston to valve clearence, because they are 13 degree I think. Not trying to say any thing bad about AFR.
    Jun 2009
    coon rapids, MN
    2000TA
    PRC LS6 stage 1 heads $1025,need better springs.do TFS heads have steam holes for using a coolant line?
    black with silver
    what is TSF im not up on all the abbreviations
    Jun 2009
    coon rapids, MN
    2000TA
    trick flow specialty .I am not up to all the abbreviations also.
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    Phantom Black Metallic
    2004 GTO
    Just had my AFR 205s ported ... the flow results are here http://www.ls1.com/forums/showthread.php?t=132950
    oklahoma
    2000 trans am
    Quote Originally Posted by GTO1_OHIO View Post
    Those NUMBERS are great. No doubt. If you can afford them.
    Texas Speed and many other places offer more cost effective factory heads that flow comparible to your AFR. Especialy for the price.
    If you are going to build a high reving, large cubic inch, or even just a high compresion, [12.5 or higher engine then you should probably look at after market heads. Or if you just have money to spend. The factory heads flow awsome for what they are, especialy after CNC.
    15 degree LS1/LS6 and any other cathedral port head will experience the same increase in flow that your AFR did, but the LS6 and equivelents will out flow your AFR head above 500 on the intake.
    Trick Flows are 13.5 degree and should create more velocity and flow better yet
    LS7 and the C5R are 12.0 degree. The LS7 are 370cfm from GM. Texas Speed sells a set that are CNC and flow over 415cfm for under $2000.00
    370cfm to 415cfm FACTORY head but CNC
    Don't be a dumb ass Damage Inc.'s Avatar
    Baltimore, Md.
    Brazen Orange Metalic
    '06 GTO
    So has anyone answered the question?
    I would also like to know if anyone has any good info on this topic.
    I was looking at the Pat. Perf. stage 3's vs TFS 220's on a LS2. More interested in actuall HP/TQ #'s than flow numbers. I would be doing a cam to match at the same time.
    oklahoma
    2000 trans am
    Quote Originally Posted by squirlnutz View Post
    No need to spend lots of money on after market head unless you just can. Factory GM heads CNC for these engines, will compare with all 15 degree after market castings. The numbers are not much different. Change valve angle from 15 degrees, stock compared to 13.5 with TrickFlow, witch unshrouds the valve and will increase velocity, and flow to and from the combustion chamber
  1. ported LS1 heads Vs. stock LS6
    By krazykarl454 in forum Internal Engine
    Last Post: 12-02-2009, 07:00 PM
  2. Has anyone ported their stock heads, and what are your numbers?
    By TransAmcoupe98 in forum Firebird / WS6
    Last Post: 08-25-2007, 05:57 AM
  3. New heads or Port/polish Stock Heads?
    By Black02LS1 in forum Western Members
    Last Post: 05-20-2007, 09:11 PM
  4. what will it cost to get stock heads ported
    By blackbird33 in forum Internal Engine
    Last Post: 04-28-2007, 02:39 PM
  5. AFR heads vs Patriot Heads.. CNC ported
    By WARP211 in forum Camaro / SS
    Last Post: 03-01-2007, 08:51 AM
