04-19-2007, 09:02 AM #1Junior Member
- Feb 2007
- vivian, la
black- 1999 Trans Am
what will it cost to get stock heads ported
i was just wondering if it would be better to get someone to port my 99 ls1 heads or be cheap and do them myself. so does anyone have a price range
04-19-2007, 03:20 PM #2Member
- Feb 2007
- Bakersfield, CA
86 Buick Grand National- 02 WS6-M6 407 RWHP
Just order TSP's ported and polished LS6 heads there not very expensive.
04-20-2007, 05:02 AM #3
I can only speak for the area that I am in (Maryland) and most guys are between 800 and 1k for a full hand porting job.
Chris Crossont
A.H.M. Performance
Baltimore, MD
04-20-2007, 08:29 AM #4Member
- Feb 2007
- Bakersfield, CA
Knowing thats how much its gonna cost to get them done definately go with the heads i mentioned about you can get them for the high end of the price range he mentioned above.
04-24-2007, 04:35 PM #5
I wouldn't suggest doing it yourself, unless you've got a flow-bench just sitting around.... There used to be a local guy here that did an exchange for $600, and he was getting them to flow great numbers.
She's baaaaaccccck...
'02 Z/28 M6 Hardtop
04-25-2007, 06:07 AM #6
$600.00 wouldn't be a bad price at all! That would make the $2,000. head porting and cam swap route possible! Most of my research from around here indicates that it would cost around $800 - $1,000. for a hand porting job.
04-25-2007, 03:39 PM #7Member
- Feb 2007
- Bakersfield, CA
2,000 for head and cam swap is easily attainable
1k for heads
600 for cam package with valve springs and pushrods
Only things left are Head Gaskets and Head Bolts and if you want a new timing chain and oil pump.
04-27-2007, 07:56 AM #8Anniversity TA
- Apr 2007
- Poway
white/Blue- 1999 Transam
I can do your heads for 800 and ship them back to you.I run Accurate Engine in Lakeside California.If you would like give me a call at 858-829-5107 and we can discuss price depending on what parts you would like to be added to the heads. Jack
04-28-2007, 02:39 PM #9Member
- Nov 2006
- texas
red- 2001 formula
I can make you a super deal on my 2001 LS1 formula heads you can send them out to have all the work done and it will minimize the down time on your car. Send me a pm if interested
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
ported LS1 heads Vs. stock LS6
By krazykarl454 in forum Internal EngineReplies: 6Last Post: 12-02-2009, 07:00 PM -
Cost for r&r heads
By lloydb3 in forum Internal EngineReplies: 3Last Post: 08-19-2008, 05:24 PM -
Has anyone ported their stock heads, and what are your numbers?
By TransAmcoupe98 in forum Firebird / WS6Replies: 0Last Post: 08-25-2007, 05:57 AM -
AFR heads vs Patriot Heads.. CNC ported
By WARP211 in forum Camaro / SSReplies: 6Last Post: 03-01-2007, 08:51 AM
