Thread: ported LS1 heads Vs. stock LS6
11-29-2009, 06:03 PM #1
ok so if i was on a tight budget. say around 500ish. and i already have comp beehive springs and titanium retainers, but im lookin for a better flowin head should i go with a set of stock LS6 heads, or take my chance with gettin my LS1 heads "Stage 3" Ported, and get the stock valves backcut 40 degrees for 500 bucks through a company i found? i'm running a tsp 220/220 .588 114 cam. does any one have flow numbers of the ls6 stockers?
Stage 3 LS1 Ported Heads
241 Casting
(These heads are flowed on a 2" valve with no pipe)
.300 lift (intake 218) (exhaust 177)
.550lift (311 intake) (241 exhaust)
Heads are flowed on a SuperFlow 600 Flow Bench
Heads are ported at 28" H2O
thanks again guysLast edited by krazykarl454; 11-29-2009 at 06:07 PM.
11-29-2009, 07:31 PM #2LSwut
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
Ported LS1 heads flow just under stock Ls6 heads. If you do a minor clean up of the LS6 heads, you're able to pick up +/- 10-20 cfm. I did mine myself and picked up roughly 25cfm. As long as you're careful and just do a clean up, you can get the better heads and do a decent port job for next to nothing on the porting side.
We put ported ls1 heads on a CETA (LS6 intake/cam/headers) and it topped out at 371HP with a tune.
I'd def say LS6 heads
11-29-2009, 07:37 PM #3
head flow info
http://www.ls1tech.com/forums/genera...ng-thread.html
11-30-2009, 03:48 AM #4
hmm.... thanks tep. yea i've cleaned up a couple dirtbike jugs. well thats very interesting. that would keep in in my budget. i guess u had a flow bench layin around tho?
11-30-2009, 05:30 AM #5LSwut
- Jun 2009
- Saint Louis, MO
no prob. kind of, at school. haha
this teacher that was helping me with the mathmatical part of flow was telling me about how he made a flow bench when he was 10 and was telling me how to build one and apparently it's "super easy" but i got lost amongst all the engineer talk
11-30-2009, 08:05 AM #6Member
- Feb 2006
- MD
Those flow numbers are BS. Especially for $500 and with cut stock valves. What shop is claiming this?
Oh, and Stage 3 usually refers to something designed for a 4" bore or larger.
12-02-2009, 07:00 PM #7
yea it sounded almost go good to be true to me too. its this shop out of Florida. well i would much rather pic up a set of LS6 heads and clean them up my self. don't they also have the sodium filled ex. valves?
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
Has anyone ported their stock heads, and what are your numbers?
By TransAmcoupe98 in forum Firebird / WS6Replies: 0Last Post: 08-25-2007, 05:57 AM -
what will it cost to get stock heads ported
By blackbird33 in forum Internal EngineReplies: 8Last Post: 04-28-2007, 02:39 PM -
AFR heads vs Patriot Heads.. CNC ported
By WARP211 in forum Camaro / SSReplies: 6Last Post: 03-01-2007, 08:51 AM -
For Trade Stock 1998 Ported and Descreened MAF Looking for STOCK ONE!
By EvilCamaroSS in forum Parts For Sale / TradeReplies: 5Last Post: 01-27-2006, 11:12 AM
