Results 1 to 10 of 10
09-27-2005, 04:00 PM #1Junior Member
- Sep 2005
- East Coast
Black- 1987 Grand National
LS6 heads/cam swap how much power
I have a 01 Z28, I bought the 02 LS6 243 heads and ZO6 cam. My car dynoed 325 with MTI Lid, Free mods, filter, HPP3, and a flowcrapper muffler through stock pipes and manifolds.
How much increase in HP/TQ can I expect after the install and a tune.
Also, I may go to LTs and catted y with Hooker cat back, how much increase if I go that route?
09-27-2005, 10:01 PM #2
if you do everything expect to see about fifty to seventy five HP increase.....it would be more if you got a better cam and also changed the intake but I would say it would probably be closer to fifty to sixty but depending on tune possibly up to 400rwhp total.
09-28-2005, 03:58 AM #3
It's a sneeky sleeping 370-380 RWHP if you add the exhaust to the z06 heads and cam. Saw another guy do this on another forum and he was in that range. He had about 350RWHP with the stock exhaust which is about on the nose of the 405HP raiting at the fly of the ls6 egnine
09-28-2005, 05:41 AM #4member since may 2000
- Dec 2002
- n/w chicago
with the heads, cam and headers, you can expect about 70 h.p or so.
a few bolt ons, 379 rwhp
11.96 @113.25
09-28-2005, 06:14 AM #5Rhino21149Guest
Originally Posted by FastRegalWE2
Are you talking about stock heads and cam? I think you'll get only about 40-45 RWHP from that. After adding them you'd have in effect a slightly lower than stock compression ratio LS6 engine with some lite mods: I know that dynos at about 365-370 RWHP in a vette which has a true dual exhaust.
Seems a shame to do the labor for only stock components, so if you will get nicely cnc's heads and use a good aftermarket cam, say something like a Crowler stage II for the LS6, and you ought to get about 60-70 RWHP increase (i.e., another 25 or 30 over the stock). Adding LTs would give you perhaps another 15 but more important would give you a lot of low and mid range torque improvement.
09-28-2005, 03:36 PM #6Junior Member
- Sep 2005
- East Coast
how bout if I threw in a 224 and LT's and catback??? 400 possible then
09-28-2005, 09:27 PM #7with a good tune and the LS6 or LSx intake then yes.......somewhere right around there.
09-29-2005, 04:15 AM #8Rhino21149GuestYou might almost make it then, but I would not bet heavily on getting all the way there. Maybe if you use a Crwler cam of that size with its high ramp rate on opening and closing, but . . .
LS6 heads, unmodified, just aren't THAT good . . . why not spend money to get them ported or larger valves put in them
In addition, pay attention to the valve spring and make sure you have the right pushrod length. I would not trust the stock springs and rockers to operate well (i.e., not float at high RPM) with a big cam. They are better than LS1 springs, but not that good.
10-06-2005, 07:38 PM #9
Check these links out for a good understanding of whats involved for good aspiration for your desired applications.
http://www.compcams.com/catalog/
http://chevyhiperformance.com/techarticles/86218/
http://www.themotorbookstore.com/ls1...8-engines.html
http://www.motorsporttech.com/fbody_engine01.asp
10-16-2005, 03:40 PM #10Junior Member
- Oct 2005
- Texas
ASC conversion # 11745- 2002 Black ebony WS6 M6
If your heads are 02 ZO6 than you have the lightweigt sodium valves! I am running these valves on my set up!!
02' Black WS6 M6 - Venom nitrous kit VCN-1000,B&B cat back ,MTI Carbon Lid,Racetronix FP kit,Holley Powershot Filter,BGRA,Accufab TB, March Pullies,MSD coils.
power antenna swap
By fbodyNATION in forum Stereo and ElectronicsReplies: 27Last Post: 06-08-2011, 11:05 AM -
Heads Cam Swap...
By Camaro69Mac in forum Internal EngineReplies: 1Last Post: 12-13-2010, 05:50 PM -
Help: Heads cam swap??
By rmftbllfan in forum External EngineReplies: 1Last Post: 04-21-2010, 02:19 PM -
heads cam swap
By Bottlefedz28 in forum Internal EngineReplies: 3Last Post: 11-10-2009, 05:49 PM -
05 GTO- L92 heads and Cam swap. Pix
By juiced99ws6 in forum Internal EngineReplies: 26Last Post: 08-16-2007, 08:23 AM
