Thread: heads cam swap
11-07-2009, 04:22 AM #1Junior Member
- Nov 2009
- Lafayette LA
RED ultra Z hood 125 shot- 02 Z28 3200 stalled
heads cam swap
early december doing a H/C swap on my 2002 z28 heres what i got
Ls2 heads W/Dual valve springs,and ultra light rockers,
tourquer v2 cam, comp cams double roller chain
also installing methonal injection to help with the nitrous system and 42#injectors and 255 fuel pump, long tube headders
any supporting items i will be needing so i can get them now? any tips?Last edited by Bottlefedz28; 11-07-2009 at 04:27 AM.
11-07-2009, 02:09 PM #2
11-09-2009, 10:39 AM #3Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
I would do an oil pump since it has to come out for the TC install. If you don't at least get a new o-ring from GM for the pickup tube.
New lifters since the heads will be off. LS7's are only about $120 a set.
Get a pushrod checker ($20) and set up a dummy lifter and measure PR length. .060-.090 preload is what you shoot for on LS7 lifters otherwise use manufacturers specs.
Make sure you PROPERLY set the wipe pattern for the new rockers. Otherwise you will see increased valveguide wear.
Good luck with the swap
11-10-2009, 05:49 PM #4Junior Member
- Sep 2009
- Ceres,CA
Black- 2000 Pontiac WS6 Trans Am
hardened 7.4 pushrods,melling oil pump would be almost a must cause the oiling systems are shitty as fuck, definitely a good tune ?? and maybe some gears depending on auto or 6spd......headers exhaust lots of factors to get full potential out of teh cam ..my buddy had same cam with stock heads and intake with full boltons and 4kstall and 373's and is runnin 11.49 consistantly all day
Heads Cam Intake Swap
By Camaro69Mac in forum Internal EngineReplies: 4Last Post: 12-17-2010, 11:47 AM -
Heads Cam Swap...
By Camaro69Mac in forum Internal EngineReplies: 1Last Post: 12-13-2010, 05:50 PM -
Help: Heads cam swap??
By rmftbllfan in forum External EngineReplies: 1Last Post: 04-21-2010, 02:19 PM -
oil change for heads/cam swap?
By jmatt07 in forum General HelpReplies: 3Last Post: 03-15-2009, 09:36 AM -
05 GTO- L92 heads and Cam swap. Pix
By juiced99ws6 in forum Internal EngineReplies: 26Last Post: 08-16-2007, 08:23 AM
