    1998 Camaro SS
    oil change for heads/cam swap?
    I wasnt gonna change my oil for the heads/cam swap bc i was told that after you change out the heads/cam to change the oil after about 100 miles but i took the old heads of the engine today and noticed the coolant going everywhere and have to wonder if a bunch of coolant got into the oil. So my question is should i change the oil before startup with new heads/cam?
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    I would start it up, and let it run up to operating temp, then I would probably go ahead and change oil after heat cycling it. But thats just my opinion.
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    I did mine during and then again after 100 miles. Probably not completely necessary but I wanted to get all the little stuff out of there that might've found it's way to the oil.
    in my Trans Am
    2000 Trans Am WS6
    yes.....change your oil....and then do it again after 100 miles......yes its a bit more money but 30-40 bucks is worth it for what you just put in your engine isnt it???
  1. Can you change cam on LS1 withiout removing heads
    By cballweg in forum Internal Engine
    Last Post: 08-23-2011, 03:08 AM
  2. Help: Heads cam swap??
    By rmftbllfan in forum External Engine
    Last Post: 04-21-2010, 02:19 PM
  3. heads cam swap
    By Bottlefedz28 in forum Internal Engine
    Last Post: 11-10-2009, 05:49 PM
  4. 05 GTO- L92 heads and Cam swap. Pix
    By juiced99ws6 in forum Internal Engine
    Last Post: 08-16-2007, 08:23 AM
