Results 1 to 2 of 2
Thread: 4-5 grinds on ws6
07-19-2007, 03:29 PM #1Junior Member
- Jul 2007
- new york
gold- 2002 trans am ws6
4-5 grinds on ws6
I have 2002 t/a ws6, 4-5 grinds when I'm getting on it, but if i work the Throttle a bit it will slide in. Is it the stock shift fork pad? and where is it?
thanx Anthony
07-20-2007, 05:19 AM #2Member
- metro Detroit area
You do realize that 5th is an overdrive and that as a "power" gear it is less that optimum, right? Hard shifting into 5th may be the basic problem but it sound like the synchro may be worn and no linger likes high energy shifts.
If what you are saying is that you have to speed-match to even shift without clashing, then the synchro and possibly the fork pads and gear synchro teeth may be toast. These components are at the rear of the trans so, a full teardown is not required to address them. It still requires removal from the car and at that point, you may as well go through the whole thing.That just what I would do, though.
t-56 grinds in 5th gear..
By 99RedTa6spd in forum Manual TransmissionReplies: 13Last Post: 01-26-2010, 05:25 PM -
5th and 6th Shift grinds
By neo74 in forum Manual TransmissionReplies: 1Last Post: 10-16-2009, 04:05 PM -
Grinds into second
By Orrin's Z in forum Manual TransmissionReplies: 5Last Post: 09-12-2008, 01:25 PM -
what really grinds my gears
By JoshieDoom in forum Almost Anything GoesReplies: 23Last Post: 03-20-2008, 06:50 AM -
98 6 speed grinds in 4th
By Vinco in forum Manual TransmissionReplies: 3Last Post: 07-10-2006, 04:48 AM
