Results 1 to 14 of 14
    New Jersey
    1999 Trans Am
    t-56 grinds in 5th gear..
    Well heres the deal, my 99 t-56 no longer goes into 5th gear, if you try all you get is a lot of grinding. It started out that it would grind a little going into gear, it stayed like that for a while but eventually got worse. Now it no longer goes into gear at all. All other gears are fine. Its been like this for about a year now, I simply skip 5th all togather when driving.. I kind of miss it tho and will be pulling the trans sometime soon to put a new clutch in anyway.. What are the possible causes?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Well it "could" be a shifter issue. Sometimes on aftermarket shifters there is an adjustment screw on the front side that needs adjustment. You could try backing this out and see if it helps, but normally though it would affect more than one gear I would think.
    My guess though is internal damage to the transmission. Worn or damaged synchronizer/blocker ring
    Member kevnstac's Avatar
    Woodstock
    1999 WS6
    Mine did the same things but started with 6th gear and eventually worked its way through 5th then 4th and reverse. Synchros were the culprit.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Try this:
    Start the car with it in neutral, leaving the clutch held down. Then try and shift into 5th. Does it grind, go in smoothy, or is there excessive resistance??
    Member tpilews's Avatar
    Tampa, FL
    '98 Z28
    Had the same problem with 5th. Synchros
    New Jersey
    1999 Trans Am
    Quote Originally Posted by Wesman View Post
    Try this:
    it grinds..
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Yep. Synchro went bad.
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by 99RedTa6spd View Post
    it grinds..
    Then you have a clutch issue as well, because no internal transmission components should be rotating when you follow that exact procedure.
    New Jersey
    1999 Trans Am
    yep slave cylinder is leaking.. just wanted an idea what to look for when i pull the trans out on monday.. havnt been able to use 5th gear for about 2 years now.. figured it's a good time to fix it since the trans is comin out anyway.
    New Jersey
    1999 Trans Am
    It also grinds as soon as I start to let the clutch pedal out if I attempt to start the car with it in 5th gear.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Hmmm...you might have a bent shift fork or synchro. It shouldn't grind like that unless the its not all the way in gear (ie bent shift fork isn't pushing the slider all the way over into gear)
    NJ
    SGM
    1998 Trans Am WS6
    Agreed. Definitely something internally damaged.
    New Jersey
    1999 Trans Am
    I'll let you know what I find, going to pull it apart next time I have some free time at work. Had an hour at the end of the day today so I pulled it out.
  1. Grinds into second
    By Orrin's Z in forum Manual Transmission
    Last Post: 09-12-2008, 01:25 PM
  2. what really grinds my gears
    By JoshieDoom in forum Almost Anything Goes
    Last Post: 03-20-2008, 06:50 AM
  3. Downshift into 3rd grinds
    By 1flynDO in forum Manual Transmission
    Last Post: 10-26-2007, 05:16 AM
  4. 4-5 grinds on ws6
    By anthonyv00 in forum Manual Transmission
    Last Post: 07-20-2007, 05:19 AM
  5. You know what really grinds my gears
    By SSwt00SS in forum Almost Anything Goes
    Last Post: 08-12-2006, 11:09 PM
