    Jun 2006
    Anaheim, CA
    1998 Camaro Z28
    98 6 speed grinds in 4th
    I autocross and drag race a bit. My Z28 just began grinding sometimes going into 4th from 1st. The other gears so far are fine.
    Could this be an issue with the Chevy shifter?
    If I need a rebuild, would it be better to get a new 6 speed? Where would I get a new 6 speed? Is a rebuild the beginning of the end?
    metro Detroit area
    I see your new so perhaps slack is due, but a search would have told you that this is a common / known problem with the original aluminum 3/4 shift fork. You will need to install a replacement iron part to solve the problem.
    Jun 2006
    Anaheim, CA
    1998 Camaro Z28
    Searching
    Thanks for the advice. What is the best way to search? How would I have searched for this problem? Thanks
    metro Detroit area
    Well, I would have stated the subject= grinds in 4th, but thats just me.
  1. t-56 grinds in 5th gear..
    By 99RedTa6spd in forum Manual Transmission
    Last Post: 01-26-2010, 05:25 PM
  2. Grinds into second
    By Orrin's Z in forum Manual Transmission
    Last Post: 09-12-2008, 01:25 PM
  3. what really grinds my gears
    By JoshieDoom in forum Almost Anything Goes
    Last Post: 03-20-2008, 06:50 AM
  4. Do you know what grinds my gears?
    By FSANE in forum Almost Anything Goes
    Last Post: 11-23-2007, 11:37 AM
  5. 4-5 grinds on ws6
    By anthonyv00 in forum Manual Transmission
    Last Post: 07-20-2007, 05:19 AM
