Thread: axle seal leak
07-09-2007, 10:03 PM #1
axle seal leak
check this out, went to the dealer to have my oil changed and had them check out a possible leak on the car, they call me and tell me that the axle seal is leaking and its going to cost 600 bucks to replace it, i about shit myself
im out of warranty. i really need an extended warranty i guess
i just cant believe it cost that much to replace the damn thing
07-10-2007, 02:05 AM #2Member
- Apr 2006
- North Canton, OH
Light Metallic Pewter- 2000 Corvette Coupe
Common problem, biggest factor is the labor with everything that needs to be dropped to get at it. Replace the fuel filter while that area is open..........
08-08-2007, 05:38 PM #3
are u talking about the rear differential cover? i know those things leak a lot. of so... its not too bad to replace, but it involves pulling the axle.
08-08-2007, 08:45 PM #4
You don't need to pull the axles to replace the rear differential cover at all. Its simple and straightforward - Unbolt the cover, drain the fluid in the process, replace the gasket, bolt the cover back on, and refill the diff with fluid through the fill hole. Very easy.
Now if you're talking about the rear axle seals, which is what the author of the thread mentioned, that involved pulling the axle to replace the seal.
To change the axle seals, you just do this: Take off the wheels, unbolt the calipers from the mounts, remove the rotors, pull the rear diff cover, remove the c-clips that hold the axles in place, carefully slide out the axle, pry out the old seal, (check the bearings while your in there), tap the new seal into place, and reverse the steps to put everything back together. $600?? Thats ridiculous to do that, get a shop manual and do it yourself.
08-09-2007, 03:37 AM #5
Moser 12 bolt axle seal issues?
By pajeff02 in forum DrivetrainReplies: 14Last Post: 09-09-2013, 07:25 PM -
Problems with axle seal. Am I being ripped off?
By BdAsBrd01 in forum DrivetrainReplies: 8Last Post: 04-03-2010, 10:08 AM -
Differential Cover & Axle Shaft Seal
By aerojt in forum DrivetrainReplies: 8Last Post: 07-15-2008, 12:46 PM -
Axle Seal Issues
By Orcus79 in forum DrivetrainReplies: 2Last Post: 07-05-2007, 11:13 AM -
Axle seal.
By Mjolnir in forum DrivetrainReplies: 3Last Post: 02-23-2007, 07:56 PM
