Results 1 to 3 of 3
Thread: Axle Seal Issues
07-04-2007, 07:06 PM #1
Axle Seal Issues
Al sarcasim can be left at the door please as this is a rather problemmatic issue, I have gone through two sets of seals in about as many weeks, the most recent was a full failure resulting in the rotor and pad getting saturated in oil. The forst two sets were installed by a shop after a rebuild.
The issue is that the axle shaft is near the same diameter of the ID of the seal and rough casting is catching the seal ring. So is there a proper way to to install the axles with our damaging the seals? I have GM aka AC Delco seals coming and really wnat to fix this once and for all so i don't cook the rear end, i can not afford a new 12 bolt or a new 10 for that matter.
07-05-2007, 05:43 AM #2Simpsons Did it!!
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
Where the seal rides on the axle may be wore down. Its a common ailment on GM 10 bolts. What you would need to is buy what they call a repair bearing, the BCA number is rp5707 I believe. Its a bearing and seal all in one piece and it changes the position where the seal rides. That should fix your problem once and for all.
07-05-2007, 11:13 AM #3
Thanks, if the new set of seals from GM don't work that may be my next option.
Moser 12 bolt axle seal issues?
By pajeff02 in forum DrivetrainReplies: 14Last Post: 09-09-2013, 07:25 PM -
Problems with axle seal. Am I being ripped off?
By BdAsBrd01 in forum DrivetrainReplies: 8Last Post: 04-03-2010, 10:08 AM -
Silverado Front Axle Seal/ Gasket
By 00 formula in forum DrivetrainReplies: 2Last Post: 11-19-2008, 06:38 AM -
axle seal leak
By issues in forum CorvetteReplies: 4Last Post: 08-09-2007, 03:37 AM -
Axle seal.
By Mjolnir in forum DrivetrainReplies: 3Last Post: 02-23-2007, 07:56 PM
