04-02-2010, 01:27 PM #1
Problems with axle seal. Am I being ripped off?
Okay, so this is the second axle seal I have had to have replaced on the TA in the past two months. The dude says that the replacement seal is "just a temp fix" and we'll have to have the whole axle replaced soon. Is this true or does dude just not know WTF he's doing? It was crapping axle grease out behind the break drum and onto the tire rim, back passenger side, even After the seal was replaced last month. I'll post some pics if needed. What should I do if it's still leaking after this replacement?
04-02-2010, 02:43 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
If the axle is grooved where the seal rides then you'll have to replace the axle for it to seal properly.
OTOH, I know they make offset axle bearings for when the axle is bad where the bearing rides. maybe they also make and offset seal? I really don't know.
04-02-2010, 05:52 PM #3
How do the wheel bearings look? I bet the bearings are worn causing you to go through seals. I know at work we always replace the bearings with the seals regardless to avoid this problem.
04-02-2010, 07:20 PM #4
04-02-2010, 07:25 PM #5
It is. Shit. Great. Something ELSE to have fixed. I've got an oil leak that they're gonna have to drop the motor to fix the leak, $1,750 for that little errand. I swear I love TA's but I must say I paid 10,500 for it in Dec. of '06 and I've had about 8,000 worth of non-mod repairs done. I'm hoping at some point to get to the bottom of the barrel and have every fucking thing that's wrong with it fixed so that eventually I can have some fun things done.
04-02-2010, 08:54 PM #6
Sounds like your mechanic should send you a Christmas card every year ... $8k is a boat load for a BMW much less a T/A
04-03-2010, 06:50 AM #7Senior Member
- Jan 2010
- texas
silver- 2000 formula
i try to fix everything ..........i dont make 100$ a hr like the stealership charges.......if i had to..........i could drop the motor myself.........for a 10$ gasket
04-03-2010, 10:05 AM #8
04-03-2010, 10:08 AM #9
Moser 12 bolt axle seal issues?
By pajeff02 in forum DrivetrainReplies: 14Last Post: 09-09-2013, 07:25 PM -
Differential Cover & Axle Shaft Seal
By aerojt in forum DrivetrainReplies: 8Last Post: 07-15-2008, 12:46 PM -
axle seal leak
By issues in forum CorvetteReplies: 4Last Post: 08-09-2007, 03:37 AM -
Axle Seal Issues
By Orcus79 in forum DrivetrainReplies: 2Last Post: 07-05-2007, 11:13 AM -
Axle seal.
By Mjolnir in forum DrivetrainReplies: 3Last Post: 02-23-2007, 07:56 PM
Yeah, no shit.
