Thread: service engine soon ?
06-21-2007, 07:55 AM #1
hey any one might know why every time i dog the ws6 my girlfriend has the light comes on with a code that has bank 1 sensor 2 and bank 2 sensor 2 low voltage ??
06-21-2007, 12:10 PM #2
06-21-2007, 05:25 PM #3
rear o2s are possibly going bad.
06-21-2007, 06:54 PM #4
It's hard to make out what you're saying... but i agree with the above, I have the same problem.
06-22-2007, 04:23 AM #5
well that is the thing it was coming on when you would floored it and so i replaced them and it is still doing it
06-22-2007, 09:16 AM #6
Well if you replaced them and all the connections are tight it sounds like the CATs might be going bad. They start to flow more than the O2 sensor thinks it should and throws a code. I have high flow CATs and this happened so I just got O2 sims and no more SES. Sims go for about 90 each. Good luck!
98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
06-22-2007, 10:59 AM #7
thanks where is the best place to get them ??
06-22-2007, 12:32 PM #8F-Body Freak
- Sep 2006
- Columbia, SC in my Garage
Red- 01 WS6(m6)
Here's the link:
http://www.ls1speed.com/catagory.cfm?catagory=Exhaust
Service Engine Oil
By ledesma54 in forum GTOReplies: 7Last Post: 11-17-2008, 03:45 AM -
Service Engine Soon
By 1 RedHot TransAm in forum Firebird / WS6Replies: 5Last Post: 11-14-2008, 08:47 AM -
Help: Service Engine Soon Light.engine Code No.7missfire
By josh68 in forum General HelpReplies: 10Last Post: 07-16-2008, 08:47 AM -
Service Engine Soon
By 2001bird in forum General HelpReplies: 2Last Post: 10-18-2006, 03:40 PM -
Washed engine with hose now Service engine soon light is on help?
By JehalinTA in forum General HelpReplies: 14Last Post: 03-30-2006, 12:59 PM
