Results 1 to 15 of 15
    houston
    Navy Blue
    ls1 trans am
    Washed engine with hose now Service engine soon light is on help?
    hey like title says I spray simple green on my engine and hosed it off... I stayed away from the PC... Ive done this before without having problems... didnt watch out for the air box could that cause something...it didnt come on until a few hours later after I washed and drove on it for a while... possible sensor went bad with water in it? should I take it to a dealer.. thanks guys
    Senior Member
    Jacksonville, FL
    Either you got something wet or maybe just a coincidence. Before going to a dealer, go to Autozone and have them read the code(s) for free.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    Kind of hard to tell you what to do if we don't know what the code is for. Borrow someones code reader or take it to Auto Zone.
    houston
    Navy Blue
    ls1 trans am
    ok Ill take it to auto zone tommorow... thanks guys... I let you know what they say and go from there
    Member 04goatinmass's Avatar
    salem ma
    04 pontiac gto
    just a little fyi autozone in my area now charges to have this done..
    Feb 2006
    Long Valley, NJ
    2002 Camaro Z-28
    You could disconnect the battery for like 10 minutes on the positive side of the terminals. Then again, im not sure, but i think it resets something in the computer and and the next time you go to inspection you might fail.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Cover up or remove as much as you can when cleaning the engine...cover the maf with a plastic bag or remove the lid/maf/bellow and block the TB opening, cover fuses...etc
    Charlotte, NC
    99 Firebird Formula
    Quote Originally Posted by PureSpeed
    It would be a better idea to actually see what the code was instead of ignoring the problem until it takes out a few other components with it. But what do I know.
    Feb 2006
    Long Valley, NJ
    2002 Camaro Z-28
    ^ good advice boss.
    houston
    Navy Blue
    ls1 trans am
    Well the light is a knock sensor.. mechanic says its not abig deal and that I should maybe try to spray contact cleaner in the connecton outside of the manifold... any idea where that is?
    San Jose CA
    99 Z28
    Quote Originally Posted by JehalinTA
    Its under the intake manifold. Its most likely rusted and needs to be replaced.
    houston
    Navy Blue
    ls1 trans am
    Is there not an outside connector for the wire.. the machanic said there is a slight chance that water got to the actual sensor and probably just got the connector wet..
    The Rookie
    Guest
    Do you have an after market Air filter that you cleaned that day as well?
    Senior Member
    Jacksonville, FL
    There are two knock sensors under the intake. The front one has a connector to the back one (under the intake) then the wire for both goes to another connector behind the intake on the passenger side.
    Edit: Weird, site reversed my lost two posts.
  1. Check Engine light vs. Service Engine light
    By bigrig73 in forum Computer & Tuning
    Last Post: 04-20-2010, 07:11 AM
  2. Help: Service Engine Soon Light.engine Code No.7missfire
    By josh68 in forum General Help
    Last Post: 07-16-2008, 09:47 AM
  3. service engine soon light
    By truckguy in forum General Help
    Last Post: 09-05-2007, 07:53 PM
  4. Service engine soon light = Check engine light?
    By jinxeng in forum General Help
    Last Post: 08-11-2006, 08:34 PM
