Results 1 to 3 of 3
    Oxnard
    2001 Trans Am
    Service Engine Soon
    My Service Engine Soon light has been on for a while. I don't know how to reset the mug.
    Aug 2006
    Missouri
    94 Camaro Z28
    Did you check the codes to see if it was something serious?
    Senior Member
    Jacksonville, FL
    Go by Auto Zone and they'll read it for free, since it's been on a while might have a couple things going on. I'd recommend getting it read and posting the code(s), but if you want to try and reset it you can - some codes throw a light immediately, some take a few ignition cycles:
    PCM Reset
    Turn key on, don't start car
    Pull PCM BATT and PCM IGN fuses in engine compartment
    Wait 5-10 min
    Turn ignition off
    Replace fuses
    Idle will need a few minutes to relearn, and will reset all the readiness tests, so if you're trying to reset it to get through OBDII emissions testing you'll need to put some miles/cycles on it before getting tested - after fixing the problem.
  1. Service Engine Oil
    By ledesma54 in forum GTO
    Last Post: 11-17-2008, 04:45 AM
  2. Service Engine Soon
    By 1 RedHot TransAm in forum Firebird / WS6
    Last Post: 11-14-2008, 09:47 AM
  3. Help: Service Engine Soon Light.engine Code No.7missfire
    By josh68 in forum General Help
    Last Post: 07-16-2008, 09:47 AM
  4. Service Engine Soon
    By CamaroDMD in forum Camaro / SS
    Last Post: 04-12-2008, 06:19 PM
  5. Replies: 14
    Last Post: 03-30-2006, 01:59 PM
