06-19-2007, 09:24 AM #1Junior Member
- May 2006
- Edmonton, Canada
Navy Blue Metallic- 1998 Camaro SS
hard to get into any gears, then...
Hello everyone, I replaced my clutch, slave, etc last september and have probably put only 2000 km on the car since-99% normal driving-no racing. Anyways yesterday I was driving home and noticed that suddenly getting into any gear was not as smooth as usual, I had to almost force the shifter into the desired gear...drove the car this morning and it briefly did the same thing and then went away. Is this a sign of bad things to come to the tranny again??? Any info would be great!!!
1998 SS-Navy Blue metalic, 6-spd,Stainless OBX-R long tubes, t-tops, leather, 17" chrome ZR1's, magnaflow catback, slp airlid, mail order tune.......
06-19-2007, 09:49 AM #2Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
SOunds like the syncros are gone bad.
06-19-2007, 09:57 AM #3Junior Member
- May 2006
- Edmonton, Canada
would they all go at once??
06-19-2007, 01:11 PM #4Junior Member
- Mar 2006
- Michigan
red- 1994 Camaro Z28
hard shifting........
Synchros ....not likely...like u said ..not all at once. Sounds as if your clutch is still not releasing completely when you depress the pedal...dang hydraulic clutches are sooooooo aggravating.
06-19-2007, 03:03 PM #5Junior Member
- May 2006
- Edmonton, Canada
what would be the likely cause of a clutch not releasing fully?
06-19-2007, 06:43 PM #6Junior Member
- Mar 2006
- Michigan
To be honest, there are several possibles. Starting with the least serious, the clutch may just need adjusting...it may be simply running out of "pedal travel" before you are fully disengaging the disc.
If not "adjustment", sometimes the pressure plate fingers will have distortion or fractures in one or more of them...with the same result..insufficient "disengagement travel".
It is even possible that the disc is partially delaminating...causing drag and incomplete disengagement.
Finally, sometimes the throwout bearing will be starting to seize, building up heat and causing the same result..not as common, though.
I am sure there are more possibilities, even, but these come to mind.
06-21-2007, 08:53 PM #7
how do you go about adjusting it.my 00 sometimes is hard to get in gear and then sometimes its like butter
Help: Hard Getting Into All Gears
By themanofsteel20 in forum Manual TransmissionReplies: 13Last Post: 09-09-2011, 01:33 PM -
Help: about to change my plastic gears for brass gears
By edrvsqz1980 in forum General HelpReplies: 17Last Post: 07-18-2009, 06:09 PM -
Hard noise when shifting gears
By DesertRat in forum DrivetrainReplies: 0Last Post: 05-26-2009, 07:23 PM -
hard to engage gears?
By eiyse98ls1 in forum Manual TransmissionReplies: 3Last Post: 08-02-2007, 04:36 PM -
3:73 gears, 3:42 gears, clutch, flywheel, plug wires
By ls1hater in forum Parts For Sale / TradeReplies: 4Last Post: 08-16-2005, 07:15 PM
