    bay area
    1998 camaro z28
    hard to engage gears?
    like title says yesterday morning i started to have problem getting into any gear even reverse.. this all happens at a stop or slow speeds. once in a gear and going its fine.. cant hear any grinding. i have to use excessive force to get into gear.. i currently have 01 slave w/ ls6 clutch with approx. 50k.. what can be my problems?
    metro Detroit area
    This sounds like the clutch is dragging . This will quickly wear the synchronizers so locate/ fix the problem before driving it too much.
    bay area
    1998 camaro z28
    Quote Originally Posted by 30thbird View Post
    hasnt happened since i posted. hopefully all is ok..
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    hopefully it was just a gremlin. if it starts doing it again, might want to check out that clutch. good luck
  1. Help: Hard Getting Into All Gears
    By themanofsteel20 in forum Manual Transmission
    Last Post: 09-09-2011, 12:33 PM
  2. Clutch won't engage
    By 99phantomss in forum Manual Transmission
    Last Post: 08-22-2010, 07:20 PM
  3. Hard noise when shifting gears
    By DesertRat in forum Drivetrain
    Last Post: 05-26-2009, 06:23 PM
  4. hard to get into any gears, then...
    By ivan1 in forum Manual Transmission
    Last Post: 06-21-2007, 07:53 PM
  5. t56 trying to engage itself when in neutral
    By tuske427 in forum Manual Transmission
    Last Post: 10-23-2006, 11:59 AM
