Thread: Anyone have an idea?
06-18-2007, 06:12 PM #1
- Jan 2007
- Southeast Pennsylvania
Black- 1998 Trans Am WS-Awesome
i just got my engine rebuilt well "remanufactured" and i have the warranty and im gonna take it to the place to have them check it out/fix it buti figured id see if anyone has an idea.... when i start my car...theres this cracking noise coming from what sounds like around the belt... now, when i turn on the A/C it squeaks and the crackling stops, but when the heat is on OR when both heat and A/C are turned off the noise comes back... really strange, really annoying, really beat considering i got my car back 4 days ago...
oh yeah and i just put on a new belt about a month or two ago, but when they were putting the engine back in they told me that it was noisy and they had to put a new belt on.... i took a look at my belt that was taken off and it was perfectly fine...
any ideas appreciated
06-19-2007, 09:18 AM #2
ImportKiller24 it sound like the bearing in either the Alternator or the Serpentine tensioner, remove the belt and spin both and listen for the noise, good luck hope this helps...
06-19-2007, 08:36 PM #3
use a long handled screwdriver as a poor mans "stethoscope". Put your ear to the handle of the screwdriver then touch it to everything up there until you find the culprit making the racket. Proven method.
Just don't get your hair or face caught in the belt......it'll leave a mark.
06-20-2007, 03:55 AM #4
06-21-2007, 12:03 PM #5
I've seen a lot of the ac belt tensioners do this. Since it changes with the a/c and it has a seperate belt, you may want to check it out.
06-22-2007, 08:28 AM #6
- Jan 2007
ive been told by the mechanics its a bad belt tensioner. the problem is there is two kinds... main drive and A/C....can anyone tell which one it is just by the information of when the noise is on and off
[A/C on.....................noise off]
[A/C off OR Heat on.....noise on]
good idea? bad idea?
By third_shift|studios in forum Multimedia SectionReplies: 7Last Post: 05-31-2007, 10:25 AM -
Good Idea? bad idea? zboner's trade off
By third_shift|studios in forum Almost Anything GoesReplies: 54Last Post: 11-27-2006, 11:19 PM -
bad idea or good idea?
By FrienldyLS1 in forum External EngineReplies: 4Last Post: 11-13-2006, 09:42 AM -
Good Idea/Bad Idea..? be gentle
By EREBUSS in forum General HelpReplies: 7Last Post: 09-14-2006, 02:45 AM -
good idea? bad idea? Fiance's Bday gift...
By third_shift|studios in forum Almost Anything GoesReplies: 25Last Post: 08-23-2006, 05:39 PM
