    Junior Member EREBUSS's Avatar
    Bay Area, CA
    RED
    1998 Camaro SS
    Good Idea/Bad Idea..? be gentle
    I HAVE BEEN CURIOUSLY LOOKING AT THE FRONT OF MY SS, TO SEE IF THERE WAS ANYTHING I COULD DO TO IT THAT WOULD INCREASE THE AIRFLOW TO THE RADIATOR, OR LID (FRAM).
    Upon taking off the ugly front black cover thing that says "CAMARO" on it, I noticed there is some material "inside" the bumper area that hypothetically could be cutout, allowing more air to rush inside to the radiator or lid area, causing what would hopefully be a little more airflow on the freeway perhaps..
    what do you guys think... ever done this, or knew somebody who did...
    positives/negatives of this idea...?
    EREBUSS
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    But why would you want to? Are you having cooling problems?
    Toronto
    2000 Z28
    i think so
    jacksonville nc
    1995/2002 camaro z28's
    if your doing it for cooling problems id try 160 therm. and adjusting the temp at which your fans turn on, i think that would make a bigger difference
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    That styrofoam you see is actually a splash guard that re-directs the air up to the front of the lid. If you ever go out and look at the engine bay when it's dark, have someone shine a flashlight in the front openings on either side of the Camaro lettering. You should be able to see the light looking down below the washer fluid tank. It's actually engineered quite well. You cut it and you'll be taking cool air away from the front of the lid.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Do the free mod-under the air filter cut away the plastic. The radiator gets all the air it needs from under the car.
    Bay Area, CA
    RED
    1998 Camaro SS
    no cooling problems, I have a fan switch, I was just curious if it would be able to increse the airflow to the lid or radiator...
    Retired Outlaw Sum Bitch
    Not enough to make any "cooling" delta....you have more than enough airflow to cool...
  1. Question: Good or bad idea.
    By LSTONY in forum Manual Transmission
    Last Post: 03-22-2013, 05:50 AM
  2. good idea? bad idea?
    By third_shift|studios in forum Multimedia Section
    Last Post: 05-31-2007, 10:25 AM
  3. Good Idea? bad idea? zboner's trade off
    Last Post: 11-27-2006, 11:19 PM
  4. bad idea or good idea?
    By FrienldyLS1 in forum External Engine
    Last Post: 11-13-2006, 09:42 AM
  5. good idea? bad idea? Fiance's Bday gift...
    Last Post: 08-23-2006, 05:39 PM
