Results 1 to 13 of 13
10-27-2005, 05:16 AM #1Senior Member
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
How difficult is it to install a LSX FAST 90mm Intake?
Buying the FAST intake manifold and was thinking of doing the install myself and was just curious if anyone else did the manifold install them self how long did it take??
Is it worth doing it your self or spending the $300 to have it installed for you?
Does anyone have any step by step instructions to doing it yourself with picts?
10-27-2005, 05:29 AM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Hey man...walk in the park.....well on the GTO anyway.....fairly straightforward.....
http://www.solent-renegades.co.uk/ca...ntake_Manifold
I think there is something at installuniversity...I'll go look for you...
10-27-2005, 05:30 AM #3Senior Member
- Sep 2005
- New York, NY
Thanks Sarge i appriciate it!!!
10-27-2005, 05:32 AM #4Senior Member
- Sep 2005
- New York, NY
How was the gain on the manifold?? Noticable??
10-27-2005, 05:40 AM #5Senior Member
- Sep 2005
- New York, NY
And also does the car need to be tuned after the manifold/90mm TB install or can you just drive away after your done??
10-27-2005, 05:50 AM #6Snake EaterGuest
perhaps a noticeable gain, but nothing "huge."
10-27-2005, 09:21 AM #7
try porting your current TB...since you already have a ls6 manifold the gains won't be noticeable unless your going for big power....my .02
10-29-2005, 02:10 AM #8
If you go with a set of AFR 205's milled .030, with Comp XER cam, either 36# or 42# injectors, aftermarket fuel rails, Walbro pump, larger MAF, appropriate 'fine tuning', LT's, no cats, good catback, and the Fast 90/NW90 combo; the gains will be impressive - in the upper 400 range for both RWHP/RWTQ.
On a basically otherwise stock car I agree with the others that the LS6 intake is fine and the gains you see from a 90/90 combo is not worth the cost.
If you're willing to ante up all the $$ for a setup similar to what I mentioned above, then get in touch with Tony @ AFR and he can help you with the setup/parts selection. Every car that has followed his recipe to the last detail has dynoed in the upper 400 RWHP/RWTQ range.
-Jay-
10-29-2005, 02:20 PM #9Senior Member
- Sep 2005
- New York, NY
HMMM Sounds like a very nice setup.. High RWHP i like i think i might look into it and about that comp cam i never heard of it.. Do you know the specs on the cam??
11-03-2005, 06:39 AM #10Senior Member
- Sep 2005
- New York, NY
Ok so i have the LS6 manifold (02 WS6) and if i decide to buy the FAST manifold with the 90mm Throttle how much power could i be expecting over my stock WS6 manifold and throttle??
And is it worth it??
11-03-2005, 09:35 AM #11BlackHawk T/AGuest
No
Not unless you do heads and cam. Your engine will then be trying to pull in a lot more air justifying your LSX. Right now it does not.
11-03-2005, 09:49 PM #12
Originally Posted by BlackHawk T/A
11-04-2005, 09:03 PM #13Senior Member
- Sep 2005
- New York, NY
I am doing heads and cam but in march i'll be doing them so i guess i should just wait till i put them in then i'll buy the LSX intake and TB....
Fast 90mm Intake
By FMR_TransAm in forum External EngineReplies: 16Last Post: 12-18-2011, 07:45 AM -
90mm fast intake
By mike keller in forum Firebird / WS6Replies: 1Last Post: 06-21-2010, 07:17 PM -
90mm Fast Intake and Custom LT Header Install
By Ghawk996 in forum External EngineReplies: 0Last Post: 03-25-2009, 05:52 PM -
New 90MM LSX Fast intake & New Nick Williams 90MM Throttle Body for LS1 $1000.00 &shp
By harnick3 in forum Parts For Sale / TradeReplies: 5Last Post: 07-30-2007, 07:23 AM -
Fast 90mm intake
By fast droptop in forum Parts For Sale / TradeReplies: 0Last Post: 06-03-2007, 02:54 PM
