Results 1 to 1 of 1
03-25-2009, 05:52 PM #1
90mm Fast Intake and Custom LT Header Install
Alright guys I finally started tearing the T/A down. I have the intake off and the Fast almost assemblied. I would like to remove the coolant lines running under the intake but don't know if they make a kit to plug off the water ports on the block! Any info is helpful on this.
Now for the Headers I have the old ones off and the passanger side in place but have run into the f**king driver side common problem. I took a hammer to the firewall but the place that I need to really hit is too close to the engine block. The last header port is hitting that small square block on the engine. I have also tried loosing the motor mount and jacking it up no help their. The last thing that I have to try loosing the rear transmission mount and lift there hopefully that will get it done. This is a bit*h to do by your self.
AHHHHHHHHHHHHHHHHHHHHHHHHHHHH!
Venting
Fast 90mm Intake
By FMR_TransAm in forum External EngineReplies: 16Last Post: 12-18-2011, 07:45 AM -
New 90MM LSX Fast intake & New Nick Williams 90MM Throttle Body for LS1 $1000.00 &shp
By harnick3 in forum Parts For Sale / TradeReplies: 5Last Post: 07-30-2007, 07:23 AM -
Fast 90mm intake
By fast droptop in forum Parts For Sale / TradeReplies: 0Last Post: 06-03-2007, 02:54 PM -
How difficult is it to install a LSX FAST 90mm Intake?
By NeeD4SpeeD in forum General HelpReplies: 12Last Post: 11-04-2005, 09:03 PM -
wtb 90mm fast intake and tb
By sscrazy in forum Parts Wanted / TradeReplies: 1Last Post: 09-08-2005, 04:28 PM
