Results 1 to 17 of 17
Thread: Fast 90mm Intake
12-04-2011, 07:01 PM #1Member
- Sep 2011
- Orlando
Black- Trans am
Fast 90mm Intake
what will be the best Setup with a 90mm Fast Intake Mainfold?
i was think a 85m SLP and Ported 85mm TB
12-04-2011, 08:42 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
SLP MAFS are crap if thats what you mean, and look for a PTM or Nick Williams (NW) Throttle Body
12-04-2011, 08:45 PM #3
12-05-2011, 03:16 PM #4
I use the Nick Williams 90mm throttle body with the stock maf and stock bellows. (it all fits) The PTM 90 tb is noce too and will save a little $.
12-15-2011, 04:32 AM #5Old Member, New Username
- Aug 2011
- Browns Mills NJ
Green- 1995 Z28 w/ LS1 Swap
Leave the maf alone and just pick up a 90mm tb...Id stay away from fast though, atleast the older ones
Heads/Cam/Intake/Stall.
404 Rwhp uncorrected @ 6400
12-15-2011, 07:14 AM #6Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Save your money and either keep the stock MAF or get the car Speed Density Tuned (instead of tuning off the MAF, you tune the car using the MAP or Manifold Absolute Pressure sensor).
The FAST90s liked to leak air. FAST fixed this problem with the FAST92s and carried it over the the FAST102s.
12-15-2011, 03:08 PM #7
I always read the problem with the FAST 90 tbs was the blades would get stuck open...
12-15-2011, 03:24 PM #8
12-15-2011, 03:39 PM #9Member
- Jan 2006
- Jamestown, NC
Red- 99 Z28
Fast 90s usually need re sealed if they havent been already.
If it was me I would do
Fast Toys 85mm Lid
04 Z06 85mm mass air
NW 90mm Tb
12-15-2011, 03:47 PM #10
Ohh. Haven't had any problems with mine, yet. (knocks on wood)
12-15-2011, 04:15 PM #11
12-16-2011, 08:07 PM #12
So you're not having any issues with your FAST 102? I've been looking into these a lot lately but I don't want to get one if it is going to give me problems.
12-17-2011, 05:20 AM #13Member
- Jan 2006
- Jamestown, NC
Red- 99 Z28
12-17-2011, 05:24 AM #14Member
- Jan 2006
- Jamestown, NC
Red- 99 Z28
Why do you say that slp are garbage? I read alot of threads about people complaining about them but none actually giving a reason why. Most of the issues are the resistors inside the maf which can be fixed in 2 mins, But the slp maf is actually a delphi maf with just a sticker over it. I have and know ALOT of people that have had slp maf and not have one issue with them.
12-17-2011, 09:26 AM #15
Ya see that's why I wasn't so sure about them. I'd probably be better off going with an ls6 intake which is much cheaper
12-18-2011, 07:01 AM #16
The MAF's got a bad rap (not just the SLP's) because people were just throwing them on and running with them.
Idealy you need to re-tune the MAF tables for any aftermarket or Delphi MAF to work properly for each application. People just aren't doing that and simply blame the MAF for their problems. It has since become internet folklore.
I agree with LS1camino, go SD tune and drop that MAF completely. I never understood the larger intakes and throttle bodies and then running the small 75mm MAF. Just doesn't make sense to me.
I personally would run the larger MAF with the larger FAST intake (choose your poison) and have the car tuned properly, or completely delete the MAF all together. It's one less electronic device to worry about.
12-18-2011, 07:45 AM #17
I got a 85mm Z06 MAF off E-bay for $40 shipped then coupled to a 22* smooth bellow with a FTP lid. And finally a FAST 92/92 ported and port matched. The port matching from the factory on the FAST intakes is HORRIBLE, I spend two days on this alone. Then cleaning up all the casting marks on the base and shell took another day sanding to an 800 grit finish. Powdercoated SOM for some bling!
90mm fast intake
By mike keller in forum Firebird / WS6Replies: 1Last Post: 06-21-2010, 07:17 PM -
Fast 90mm Intake and ARP Bolt Kit
By AFASTYZFR1 in forum Parts For Sale / TradeReplies: 1Last Post: 09-09-2008, 03:54 AM -
New 90MM LSX Fast intake & New Nick Williams 90MM Throttle Body for LS1 $1000.00 &shp
By harnick3 in forum Parts For Sale / TradeReplies: 5Last Post: 07-30-2007, 07:23 AM -
Fast 90mm intake
By fast droptop in forum Parts For Sale / TradeReplies: 0Last Post: 06-03-2007, 02:54 PM -
wtb 90mm fast intake and tb
By sscrazy in forum Parts Wanted / TradeReplies: 1Last Post: 09-08-2005, 04:28 PM
