Results 1 to 13 of 13
Thread: LS7 Crate Motor...Will it Fit???
10-25-2005, 04:50 PM #1Junior Member
- Oct 2005
- Indiana
Black- 2002 Camaro SS
Whats up guys, Im new here
My friends dad has a 2001 Camaro SS, he is wanting to do a motor swap to the GM Performance 427ci LS7 Crate Motor. Its a lot of money ($13,000 TurnKey) and I was wondering if this will work? I know its a 505hp motor, but it has a high compression ratio....so is it safe to tell him his plans on strapping a blower on it can go out the window??
Thanks
10-25-2005, 07:29 PM #2
if you lower the compression then i dont see why it couldn't work?
10-25-2005, 07:37 PM #3
does the ls7 need a diff pcm and harness? what is needed to swap in a ls7...anyone know?
10-26-2005, 02:24 PM #4Junior Member
- Oct 2005
- Indiana
Originally Posted by Zboner
True, But I dont think he wants to mess with that, he was just wanting to Buy it and strap a blower on there, so I told him with it being a high compression motor(I think 12.0:1) then it would not be the right thing to do.
10-26-2005, 02:29 PM #5Junior Member
- Oct 2005
- Indiana
Originally Posted by SeVeReDiStOrTiOn
Im not for sure??
So do you guys say it will Fit in there, I mean going from a 5.7 thats JAM PACKED in there to a 7.0 is a bit off no?? I just dont think it will fit
10-26-2005, 08:46 PM #6badass67Guest
Originally Posted by 02SS
The LS7 is a smallblock engine, it may be tight, but it should fit.
10-26-2005, 09:42 PM #7
cool! I want one!
10-27-2005, 06:09 AM #8quicky06Guest
you wont just be able drop this in. first of all your going to need a new rearend. and it has a dry sump oil system(not sure if this will effect anything or not but just getting it ot there) you should be able to get by with the stock PCM all the ls7 is is a less beaffy C5R.
10-27-2005, 06:13 AM #9
i do not see any reason why it would not work man.
10-27-2005, 09:05 AM #10
what about the whole drive by wire deal? does the pcm control that?
10-27-2005, 12:48 PM #11Miss Pennsylvania
- West Cheter, PA
'98 Black Gone :(- 01 WS6 Midnight Blue
i would have made sure that everything would go together before i bought the motor, and ure not going to be able to just drop the motor right in
good luck
let us know how it turns out, i was even thinking about an ls7 swap in the future.
10-27-2005, 02:45 PM #12Junior Member
- Oct 2005
- Indiana
Thanks to all you guys for the help. Believe me I told him to ask around first, and he said he asked the guy he was ordering it from and he said it will be tight, but will fit. I'll Post pics up of everything and then a Video feed after its done of the car
2002 Camaro SS:
383 Stroker Motor From DSE - 445HP
Tremec T-6
Moser Rear End - 373's
A lot more, but wont Fit
10-28-2005, 06:14 PM #13Member
- Oct 2005
- Oklahoma
Sunset orange- 01ss,85 pu,04ramdsl
It can be done.it will all fit just gonna have to be willing to invest a little time into building some stuff yourself and finding out what will work for your application.
LSX 454 crate motor
By CAMAROmj454 in forum General HelpReplies: 10Last Post: 08-26-2011, 05:20 PM -
ls3 crate motor...480 h.p.
By 02transamce in forum Internal EngineReplies: 14Last Post: 01-08-2010, 05:14 PM -
Crate Motor?
By speed disease in forum Parts Wanted / TradeReplies: 4Last Post: 05-24-2006, 05:14 PM -
Crate Motor?
By speed disease in forum Almost Anything GoesReplies: 26Last Post: 05-21-2006, 03:09 PM -
crate motor?
By speed disease in forum General HelpReplies: 3Last Post: 05-17-2006, 01:12 PM
