Results 1 to 15 of 15
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    ls3 crate motor...480 h.p.
    http://www.crateenginedepot.com/LS37...9-P2218C2.aspx
    well,what do y'all think?i think this would be a good replacement for my ls1 in my 02 t/a ws6. opinions?
    also,this engine's throttle body is drive by wire,what do i need to replace(besides the tb)to retofit to a cable drive throttle body?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    for that kind of money you can get an 402/ 408 or a little bigger and get over 500 rwhp. if that price was about 1500.00 less it would be a good deal.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    402/408 complete engine? where do i call! lol
    Member 4thGenTA's Avatar
    Mar 2009
    farmington
    2002 firebird trans am
    they have a complete tech article on gm high tech performance mag. not sure what issues they were but it shows swapping the ls3 into a 98-02 camaro, maybe you could look up the website of the magazine.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    i will look for those articles,thanks!!!
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    found the article,thank you for telling me about it! provided a lot of info about this ls375 swap into a 4th gen f-body.
    Mar 2009
    farmington
    no problem
    Dec 2009
    Pennsylvania
    1971 vette
    SDPC had 405hp LS6 longblocks for $3195 plus $129 shipping in the 48..... http://forums.corvetteforum.com/c5-t...or-3115-a.html This was at the beginning of the month though, no idea if they still have them.
    Dec 2009
    Pennsylvania
    1971 vette
    SDPC has 405hp LS6 long blocks for $3195 plus $129 shipping http://forums.corvetteforum.com/c5-t...or-3115-a.html if this is a double post sorry, it did not show up initially....
    Quote Originally Posted by FI427 View Post
    i dropped a ls6 in mine and couldn't be happier... and they are way more than 405hp... i dynoed almost 390 rwhp before the engine was even broken in...
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Crate engine depot offers a ls6 crate engine for $5,295,I was thinking for just a little over a grand more I could get the hot cam equipped ls3.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    you want the LS6 service engine - $3200 and an excellent replacement for the LS1.
    http://www.crateenginedepot.com/stor...8-P2477C0.aspx
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Quote Originally Posted by DaddySS View Post
    This is the way to go and is a direct bolt in.
    Keep in mind guys that the LS3 would need 2 harness extensions (cam and knock sensor) and a 58x to 24x conversion box from lingenfelter to even work with the existing ECM and harness in a 4th gen. Add it all up and the LS6 with a cam swap and LT's is a good match performance wise and a much easier/cheaper route.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Junior Member Thunda's Avatar
    Albany,Ga
    2001Ws6 TransAm
    02, I am thinking about doing the same swap that you are, for the following reasons. The swap was begun in the Feb 09 GM High-Tech Performance, pg 038, by Rick Jensen the ex editor of the magazine, and finished in the March 2009 issue. He had to purchase some items from Lingenfelter Performance, but over all the swap, the warranty and the performance makes for a good street performance and good times at the strip. The final rwhp 434 and rwtq 432. The total swap with everything $7,240.00. Labor not included. You figure $2000, so for $10,000 you can have a strong running, butt whupping car and not worry will it blow up the first time you run the H___ out of it.
    2001WS6 T/A slp lid, smooth bellows, Taylor Thundervolt wires, Bosch+4, Vig 3200 stall, BM trans cooler, SLP 3" Y-pipe, 3" corsa catback, preditor custom tune by RWTD, 275/17BFG'S. 1976T/A 455-4spd-3:42
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    talked to the guy at speedsouth in pelham,al and he said around 2,000 labor for a engine r&r. i'm still planning the the engine replacement,trans and 12 bolt on tap for this year because they are needed badly. btw anyone want a two hundred thousand mile 10 bolt? i sell it cheap,lol.
  1. LSX 454 crate motor
    By CAMAROmj454 in forum General Help
    Last Post: 08-26-2011, 05:20 PM
  2. Crate Motor?
    By speed disease in forum Parts Wanted / Trade
    Last Post: 05-24-2006, 05:14 PM
  3. Crate Motor?
    By speed disease in forum Almost Anything Goes
    Last Post: 05-21-2006, 03:09 PM
  4. crate motor?
    By speed disease in forum General Help
    Last Post: 05-17-2006, 01:12 PM
  5. LS7 Crate Motor...Will it Fit???
    By 02SS in forum General Help
    Last Post: 10-28-2005, 06:14 PM
