Results 1 to 11 of 11
Thread: LSX 454 crate motor
08-20-2011, 05:44 PM #1Junior Member
- Aug 2011
- THE WASTELAND
BLACK- CAMARO 1975 BBC454/TKO600
LSX 454 crate motor
I am taking a hard look at this motor right now. Is anyone running this motor in there cars? How do you they like it? I am thinking of using the Holley High Ram with it so it'll run all the way to the top and make good HP. I might add a 75-125hp shot just for fun,lol. What size injectors should I use with something like this? Any advice would be great. Thanks!
James
08-22-2011, 05:48 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I don't have that motor, but I wouldn't mind one in my car. Some folks will run a FAST 102mm intake and throttle body on those motors. They are badass if you ask me.
08-22-2011, 05:57 PM #3Senior Member
- Apr 2008
- Madison, WI
With the bores that big, the cylinder walls get a little thin which limits you to naturally aspirated. No boost no nitrous.
08-22-2011, 06:05 PM #4
I have been thinking about this engine myself although I was thinking of using the LS7 intake assembly.
08-23-2011, 02:58 AM #5Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Personally, you're paying a lot for the LSX Block ($2500 if I remember correctly). I may be biased, but I'd get a 402/416 LS2, a 418/429 LS3, or a 408/421 LQ9 for a few thousand dollar cheaper and still have respectable power.
Also, a 75-125 shot on a 600whp motor is barely going to do anything for you. I'm planning on spraying my 300whp GTP with a 125 shot. I would spray a two stage (an initial 100 shot, then a 150-200 shot for the second stage).
No necessarily...the LSX Blocks have been pushed over 2500hp with twin turbos. They were build with high hp in mind, a N/A build for a LSX Block is easy street for it.
If you want the standard configuration intake manifold, get a FAST 102. If you want the best flowing intake for that kind motor, get a Super Victor or a Victor Jr with a good elbow (no Edlebrock's elbow...too restrictive).2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
2000 Pontiac Grand Prix GTP: Twincharged w/ a T67 Turbocharger
2007 Chevrolet 3500 Dually Duramax: 3" Downpipe, Dual 4" Exhaust, EFILive Tuning
08-23-2011, 10:20 AM #6LSwut
- Jun 2009
- Saint Louis, MO
Arctic White & Black- '98 WS6 M6 - SWAPTIME!
I've only heard great things about it
08-23-2011, 06:31 PM #7
08-24-2011, 11:35 PM #8James Bond
- Aug 2007
- Texas
gorillavettes was a LSX434, with the twin turbos
08-25-2011, 06:27 PM #9Senior Member
- Apr 2008
- Madison, WI
Thats the biggest one I've heard yet. I've read about a 427 LSX twin turbo and 400 LSX twin turbo. Have you guys seen some of the horrible core shift pictures of the LSX on the net? The more I read about this LSX, the scarier it gets. Hopefully GMs quality control have solved this core shift issue.
Here's a pic of a cutaway demo block GM has been showing around at car shows. Look at how thin the cylinder wall is at the 10 o'clock position on #6 (second from the left). That cylinder core shifted when they poured the casting.
If you go out and buy a $10,000 LSX 454 and wanna do something real serious with it, I'd suggest you tear it down and have it sonic tested for thickness.
08-25-2011, 09:34 PM #10Junior Member
- Aug 2011
- THE WASTELAND
OMG!!! Look at that block! That is unbelievable! Man, maybe I'll just go the way of small motor + boost after all. That is scary right there, I got a little more homework after all. damn....
08-26-2011, 05:20 PM #11Senior Member
- Apr 2008
- Madison, WI
BTW, I think the 2 lefthand cylinders are bored to the 454 size and the 2 RH cylinders are...I'm not sure what size. But you can see the difference.
ls3 crate motor...480 h.p.
By 02transamce in forum Internal EngineReplies: 14Last Post: 01-08-2010, 05:14 PM -
Crate Motor?
By speed disease in forum Parts Wanted / TradeReplies: 4Last Post: 05-24-2006, 05:14 PM -
Crate Motor?
By speed disease in forum Almost Anything GoesReplies: 26Last Post: 05-21-2006, 03:09 PM -
crate motor?
By speed disease in forum General HelpReplies: 3Last Post: 05-17-2006, 01:12 PM -
LS7 Crate Motor...Will it Fit???
By 02SS in forum General HelpReplies: 12Last Post: 10-28-2005, 06:14 PM
