Thread: 3 channel abs to 4 channel abs
06-04-2007, 11:29 AM #1Junior Member
- Jun 2007
- Coarsegold, ca
pewter- 00 z28
Hey Guys,
I have a 00 z28 with a 3 chanel abs set up. I have a line on a low mileage
4 chanel abs rear axle set up. Is it possible to install this in my car and still retain the factory abs option?
I realize the factory 4 chanel abs option was for cars equipped with traction control which my car does not have it. I am wondering if the pcm could be calibrated to work off of one of the rear wheel speed sensors or could you in some way modify the housing to accept the single channel set up?
Thanks for your input,
Doug
06-04-2007, 03:44 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Don't know if it's possible? My advice is to find another 3 channel and go with that. Put a complete LS1 M6 3.42 rear in mine, both 3 channel - plug and play.
06-06-2007, 08:26 PM #3
no. there is a different reluctor ring in your diff on the 3 channel rather on the axle ...the sensor counts speed differently, it will not work,unless your drill a hole in the 4 channel diff and tap a thread for the sensor, more trouble than its worth, if you want to upgrade get a 12 bolt OR rebuild yours
06-14-2007, 09:54 AM #4Member
- Mar 2007
- NC
NBM- 1998Z28
Don't believe everything you read on here. Sure you can.
http://www.ls1tech.com/forums/showthread.php?t=617761
3 channel or 4 channel
By 1badmonza in forum DrivetrainReplies: 5Last Post: 01-31-2011, 08:45 PM -
Help: Wacky 3 channel/4 channel issue
By rel3rd in forum General HelpReplies: 20Last Post: 01-03-2011, 05:00 PM -
3 and 4 channel help please
By dklowrider in forum DrivetrainReplies: 12Last Post: 08-15-2009, 05:59 PM -
Trade 4 channel 3.42 rear for 3 channel, and other
By eddielb in forum Western MembersReplies: 1Last Post: 11-03-2008, 06:24 PM -
converting 3 channel abs to 4 channel
By 02T/AWS6 in forum DrivetrainReplies: 0Last Post: 11-04-2006, 11:24 AM
