Results 1 to 20 of 21
Thread: Wacky 3 channel/4 channel issue
01-03-2011, 11:57 AM #1
Working on my buddies 99 Z28. The "original" job was for me to build him a 4 channel 10 bolt rear and swap it for his 3 channel presently in the car...(he assumed that since the car has the ASR button, it had simply gotten the wrong rear installed sometime before he owned it)
He has 3 channel rear in the car. Wiring harness has just the one wire going to the differential, plugging into the factory 3 channel ABS sensor. There's only the two brakelines going to each caliper, and where the wiring connector comes through the driver's side rear floorboard, it looks like it's all original and un-touched.
Here lies the problem...
Car has an ASR button on the dashboard, above the radio, where they usually are.
Car has all the brake related warning lights illuminated.
ASR, ABS INOP, BRAKE
Owner of car checked codes and code said faulty left rear abs sensor...
Now I KNOW that only 4 channel cars (ASR/TCS) have 4 wheel sensors.
I also know that only 4 channel cars should have the ASR button.
Like I said, code says LR sensor is bad, but the car definitely has a 3 channel rear in it right now, and it looks like it's been there forever...
On my old 2000 SS, I am 99% sure that I had more wiring and brakelines than this car has, so what the heck is going on here?
Does anyone have a picture of the 4 channel wiring/plumbing under the rear of the car? I strongly feel that this car's wiring/plumbing looks different than my old 2000 Camaro did.
.2019 Silverado LT Z71 5.3, 8L90E
2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear, TURBO...
9.32@147
01-03-2011, 02:27 PM #2
does it have the ASR/TCS unit in the engine bay??
01-03-2011, 03:05 PM #3
01-03-2011, 03:08 PM #4
yea...
you can see it in this thread with pics
http://www.ls1.com/forums/showthread.php?t=70855&page=2
01-03-2011, 03:27 PM #5
It looks like every pic on that first linked page has THREE cables coming from it.
The car in my driveway has TWO cables coming from it and the one hooked to throttle body looks to go in towards the firewall, NOT to the motor thing like the three cabled ones do.
This car is supposed to be a B4C or whatever the code is for police type vehicle. If that makes any difference?
01-03-2011, 03:35 PM #6
mines a 99 and i have 3 lines...one going to the TB and 2 going to the driveside firewall
01-03-2011, 03:37 PM #7
01-03-2011, 03:48 PM #8
Yours is 4 channel, I take it?
That's my thoughts as well....BUT, it does indeed have the ASR button, which is very weird. I know the dashlights (that are all lit up) aren't a great diagnostic tool, since I guarantee that they don't use different clusters for 3 channel vs. 4 channel cars...maybe it's some fluke, I'm dumbfounded....and kinda pissed that I totally rebuilt this guy a nice 4 channel rear (even welded the axle tubes to the center section) that is no good to him now...
01-03-2011, 03:50 PM #9
01-03-2011, 04:03 PM #10
TCS/ASR/ABS/4 channel/3 channel, blah
LOL...
Yes, stock, complete rebuild. Drivetrain rebuilding is what I do for a living, this was just a side job for my buddy.
Started with low mileage (45K) housing and axles, cleaned and painted, welded axle tubes, new axle bearings and seals, new carrier bearings, new pinion bearings, solid adjustable pinion spacer, new pinion seal, gears are low mile 373's, and it is low mileage Torsen differential. He told me to sell it to cover what I have done so far, but I wouldn't even know what to ask if I did that...
and it's VERY WEIRD that he gets a LEFT REAR WHEEL SENSOR codeLast edited by rel3rd; 01-03-2011 at 04:05 PM.
01-03-2011, 04:06 PM #11
01-03-2011, 04:12 PM #12
I know...
The housing and axles were mine, bought as a complete 4 channel rear (minus backing plates), with a brand new Eaton differential, 342 gears, and an LPW girdle, for 150 bucks...
I had the housing and axles laying around for 2 years and gave them to the guy, then he asked me about building him a rear....and here we are...
I still have no clue why he is getting a bad LR wheel sensor code...
01-03-2011, 04:14 PM #13
01-03-2011, 04:23 PM #14
well....That's how this whole episode started...
He "thought" the car was a 4 channel and that someone had put a 3 channel rear in, sometime in the past, mainly due to the code he's getting, and knowing it doesn't have any rear wheel sensors at the moment. He bought all the bearings, seals, paint, etc., even the wheel speed sensors, and figured he'd just get me to build him a nice 4 channel rear to swap back in, but it doesn't look like (to me) that this car has ever been a 4 channel car.
Why it has the ASR button, or why it's getting a faulty L.R. sensor code, is a mystery at this point.
01-03-2011, 04:26 PM #15
01-03-2011, 04:32 PM #16
I think there is more to the story...all I know is what I see and what he's told me...unfortunately, the two versions don't jive together.
What sucks is that I got the car all jacked up on stands, got some tools out, got the compressor all pumped up, hose unrolled, tires off, and then come to a standstill...not as bad if it wasn't 30 degrees outside, where I am working on it...
01-03-2011, 04:42 PM #17
the car might have had TCS and then someone wanted to delete it and got a diff rearend and cable setup for the engine bay to they could delete the unit itself???
does it look like it had a unit on the pass fender at some point???
01-03-2011, 04:49 PM #18
01-03-2011, 04:55 PM #19
01-03-2011, 04:59 PM #20
3 or 4 channel???
By xmarkx in forum DrivetrainReplies: 12Last Post: 09-09-2010, 05:55 PM -
Trade 4 channel 3.42 rear for 3 channel, and other
By eddielb in forum Western MembersReplies: 1Last Post: 11-03-2008, 06:24 PM -
3 channel or 4 channel
By slowmaro305 in forum DrivetrainReplies: 3Last Post: 10-20-2008, 08:19 PM -
3 channel 3.42?
By 96t/a in forum DrivetrainReplies: 2Last Post: 01-09-2008, 10:06 AM -
converting 3 channel abs to 4 channel
By 02T/AWS6 in forum DrivetrainReplies: 0Last Post: 11-04-2006, 11:24 AM
